Run it till it gets worse!?!?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CambridgeYota, Apr 30, 2024.
  1. Apr 30, 2024 at 6:11 AM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    Carrier bearing. I was experiencing the same conditions that you describe. Get under the truck and push up on the drive shaft near the carrier bearing. If there if play/movement, it's probably due to be replaced. I changed mine out along with new u-joints by watching videos of the process. Not a big deal.
    CambridgeYota[OP] likes this.
  2. Apr 30, 2024 at 7:40 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I think it's more of a tolerance issue with the OEM needle bearing. THe ECGS alternative has tighter clearances ... this video explains it: https://youtu.be/BOvoM5irtEc?si=OPTlOSz_HUmVpk6v
  3. May 9, 2024 at 1:33 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Update?
  4. May 9, 2024 at 5:11 AM
    CambridgeYota
    CambridgeYota [OP] Member
    Cambridge, MA
    2018 Tacoma
    I picked it up at the first dealership to bring it to the other dealership for a second opinion. And of course, the vibration was gone. The second dealership had me ride-along with a technician and he couldn't detect any abnormal vibrations. I've been driving it a couple of days now and I still feel a slight vibration at times, but nothing like what I felt that compelled me to bring it in in the first place. I don't think I'm crazy. It was bad enough that I was afraid I'd have to get it flat bed towed. The tech at the second dealership said that it was possible that the slip joint was binding and that it freed up. Sounded like a reasonable explanation. Im going to keep an eye on it and be sure to grease the heck out of the one greasable Ujoint and splines of the slip joint.
