Run to the Hills! - Jason's 100% Build-Free Colorado GTFO Build
Discussion in '1st Gen. Builds (1995-2004)' started by jubei, Apr 17, 2016.
  1. Oct 21, 2017 at 5:02 PM
    #1381
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    hmm how do you know your shaft is bent?
    My driver side wheel wobbles down the highway a bit..so i suppose mine could be too haha
    SilverGhost and jubei[OP] like this.
  2. Oct 21, 2017 at 5:14 PM
    #1382
    jubei
    jubei [OP] would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Welllll...
    It wobbles when it goes down the highway :p
    When I noticed it the first time was on 128 coming into Moab. Didn’t think anything of it at the time. After I gassed up and headed out 191 toward Monticello, I felt it again, but worse. Looked back and saw noticeable runout on the driver side while the passenger side tracked perfectly.
    I thought I might have lossened some lugs, so I pulled over and jacked it up, set the e-brake and the torques were perfect. That told me that it was probably a bent shaft, and when I took the e-brake off and tried to rotate it, it would spin for 90 degrees and then I couldn’t turn it. My thought was that the shaft being bent meant that I was rubbing the brake shoes during part of the rotation. (Exactly what was happening).
    Took it to the Jeep guys at M40 (yeah yeah), and they confirmed that it was a bent shaft but NOT a bent housing.
    Drove just fine below 60, except at 35 it shimmied like crazy. Must be resonant at that speed.
  3. Oct 21, 2017 at 5:16 PM
    #1383
    Blackdawg
    Monte
    Wyoming/St. Louis
    huh. Well good thing im swapping axles anyways haha sounds like something i have. Oh well.
    SilverGhost likes this.
  4. Oct 21, 2017 at 5:16 PM
    #1384
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Yeah mine wobbles. So I assume it’s bent. My housing is also bent. You can see it. :anonymous:
    jubei[OP] likes this.
  5. Oct 21, 2017 at 5:19 PM
    #1385
    Blackdawg
    Monte
    Wyoming/St. Louis
    huh..i wonder what caused that.......
    :luvya:
  6. Oct 21, 2017 at 5:20 PM
    #1386
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    jubei[OP] and Blackdawg like this.
  7. Oct 21, 2017 at 5:21 PM
    #1387
    Blackdawg
    Monte
    Wyoming/St. Louis
  8. Oct 21, 2017 at 5:23 PM
    #1388
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Ha as much as I want to own that I can’t :D I’ve overloaded the bed with dirt several times.
  9. Oct 21, 2017 at 5:24 PM
    #1389
    Blackdawg
    Monte
    Wyoming/St. Louis
    hauling dirt...i bet that was it..was it also at the....mall... :D
  10. Oct 21, 2017 at 5:39 PM
    #1390
    jubei
    NoCo
    Stuff. Also things.
    Monte beat me to it!
    SilverGhost[QUOTED] likes this.
  11. Oct 21, 2017 at 5:41 PM
    #1391
    jubei
    NoCo
    Stuff. Also things.
    TMFF[QUOTED] likes this.
  12. Oct 21, 2017 at 6:45 PM
    #1392
    jubei
    NoCo
    Stuff. Also things.
    So @TMFF, since there are no stupid questions, only stupid people...
    I’m assuming that the shafts are the same for both sides on my e-locker axle?
  13. Oct 21, 2017 at 6:45 PM
    #1393
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yes
    jubei[QUOTED][OP] likes this.
  14. Oct 21, 2017 at 6:52 PM
    #1394
    jubei
    NoCo
    Stuff. Also things.
    :headbang:
    So basically I need an axle (or two :drevil:) seals and bearings? And then have a shop press the bearings on? Install seems pretty easy after having installed my third.
  15. Oct 21, 2017 at 6:57 PM
    #1395
    Blackdawg
    Monte
    Wyoming/St. Louis
    Need a way to press the back plate off the current axle which means pressing the old bearings out. Can just use a large piece of tubing to put the new bearings in. Most important part is tapping the retainer rings into the right spot. Which again you can use just a long piece of tubing. Whole process is pretty simple. Just takes the right tools. Brett fabbed up his own and did his and we did mine. Worked great. Not sure I'd have a shop do it
  16. Oct 21, 2017 at 7:05 PM
    #1396
    jubei
    NoCo
    Stuff. Also things.
    Awesome. Thanks, Monte. I just thought that you had to have a press with some gawd awful tonnage.
  17. Oct 21, 2017 at 7:06 PM
    #1397
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nah. 20t harbor freight one will work to press it out plus the tool.
  18. Oct 21, 2017 at 7:19 PM
    #1398
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Tim has a press. Just saying. Right @TMFF :D
    jubei[QUOTED][OP] and TMFF like this.
  19. Oct 22, 2017 at 12:07 PM
    #1399
    Adventurous
    Adventurous Well-Known Member
    Colorado
    15 DCLB SR5
  20. Oct 23, 2017 at 4:04 PM
    #1400
    jubei
    NoCo
    Stuff. Also things.
    It’s tempting, but I think I’ll stay semi-float for the time being. FF would be sweet for sure, but it’s a rabbit hole of it’s own with sourcing all of the small parts that it requires.
    The longfields are reasonable cost, in addition to being a nice upgrade in strength with the chromo shafts. For what I do, that feels like the right approach. I also have to shell out $170 for new 650# coilover springs, so that’s a factor as well.
