Run to the Hills! - Jason's Completely Stalled Colorado GTFO Build
Discussion in '1st Gen. Builds (1995-2004)' started by jubei, Apr 17, 2016.
  1. Apr 21, 2018 at 9:08 AM
    #1541
    jubei
    jubei [OP] would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Thanks for he heads up, Brian. I wasn’t too worried about the tire wear with it not being my daily driver, but I don’t like the idea of inducing scrub issues as well. I got greedy with caster and probably shouldn’t have.
  2. Apr 21, 2018 at 9:12 AM
    #1542
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    I cant remember what numbers we got on @SilverGhost. I want to say we stayed around -.5° camber with similar caster numbers. I was thinking with LT numbers close to 5° caster was possible with close to stock camber
    SilverGhost likes this.
  3. Apr 21, 2018 at 9:22 AM
    #1543
    jubei
    NoCo
    Stuff. Also things.
    Do you still do alignments?
  4. Apr 21, 2018 at 9:24 AM
    #1544
    thefatkid
    Brian
    Colorado
    2004 thingy
    In a couple weeks I could. They cut off all side work in the shop because they used it as one of the excuses to let a poor performer go. I was told to hold off for a while.
  5. Apr 21, 2018 at 9:25 AM
    #1545
    thefatkid
    Brian
    Colorado
    2004 thingy
    What arms are you running? I thought you were LT but I just read you're mid travel
  6. Apr 21, 2018 at 9:29 AM
    #1546
    jubei
    NoCo
    Stuff. Also things.
    Thanks. I’ll probably take you up on that and consider this an expensive lesson learned. I’m not a smart man.
    All-Pro UCAs, stock LCAs.
  7. Apr 21, 2018 at 10:06 AM
    #1547
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yeah and i can't even get 3º castor with my LT kit. But pretty sure something is bent anyways haha
    jubei[OP] likes this.
  8. Apr 30, 2018 at 5:11 AM
    #1548
    jubei
    NoCo
    Stuff. Also things.
    Hit the 70,000 mile mark and took the opportunity to change the oil. I also threw new belts on and replaced the bearing in the AC idler pulley. Really straightforward and now she purrs like a kitten. No more intermittent whistling and screeching!
  9. May 4, 2018 at 9:00 AM
    #1549
    jubei
    NoCo
    Stuff. Also things.
    Any of y’all done plugs and wires on the 3.4? How much of a dick pain is it?
  10. May 4, 2018 at 9:04 AM
    #1550
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Not a huge PITD. Driver side is a little tougher but not bad. Did it in 2 days :anonymous: Just make sure you put the correct wires back on the correct plug :anonymous: :anonymous: :anonymous:
    Only idiots would do that :anonymous:
    It'll take maybe 2-3 hours depending on how many beer breaks you take :thumbsup:
    jackn7, Plastics Guy, rngr and 2 others like this.
  11. May 4, 2018 at 9:59 AM
    #1551
    jubei
    NoCo
    Stuff. Also things.
    Nice! Thanks for the quick reply, Josh!
    BYJOSHCOOK[QUOTED] likes this.
  12. May 4, 2018 at 10:19 AM
    #1552
    cynicalrider
    cynicalrider #NFG
    Jersey
    LMK how it goes, because plugs, wires, and fuel filter are on my upcoming maintenance mod list.
  13. May 4, 2018 at 10:31 AM
    #1553
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I probably should do fuel filter. Add that to HG replacement, steering rack and timing belt/therostat here soon and new body mounts
  14. May 4, 2018 at 12:35 PM
    #1554
    jubei
    NoCo
    Stuff. Also things.
    For sure, Mike.
    I probably won’t get them done for a week or two because I’m moving, but hopefully it goes smoothly.
    You have a lot on your plate, Josh! Should be like new when it’s all done, though.
  15. May 4, 2018 at 12:38 PM
    #1555
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    How'd you kill a HG?
  16. May 4, 2018 at 12:44 PM
    #1556
    BYJOSHCOOK
    Josh
    Check Out My Builds
    It's waiting until a DD comes so I can leave it for weeks.
    I didn't it's just slowly leaking so I need to replace it sometime soon. I'll do it when I have the engine ripped apart
  17. May 4, 2018 at 12:52 PM
    #1557
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    It's easy. Pop off the intake tube to make it easy. x3 10mm bolts for the ignition coils. Pop em out. Put new ones in. Good to go. I recommend changing out one wire at a time, helps not to mix them up.
  18. May 4, 2018 at 12:53 PM
    #1558
    jubei
    NoCo
    Stuff. Also things.
    Thanks for the input, Jake!
    Tacofire98[QUOTED] likes this.
  19. May 4, 2018 at 3:29 PM
    #1559
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Hey I have some OEM plugs you can have that I never put in my taco. I bought them when I was having the throttle body issue. I thought they where the plugs but wasn't. So they are just sitting in the garage.
  20. May 4, 2018 at 7:34 PM
    #1560
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's easy with the intake off :p
    Not bad though. I just put oem wires on for 40 bucks too and new plugs but I had the whole intake off and have 3x the mileage you do haha
