Run to the Hills! - Jason's Completely Stalled Colorado GTFO Build
Discussion in '1st Gen. Builds (1995-2004)' started by jubei, Apr 17, 2016.
  1. Nov 2, 2018 at 9:13 AM
    #1741
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Wouldn't accomplish much more sitting in your driveway. :luvya:
    Should be on my truck! :D
  2. Nov 2, 2018 at 10:43 AM
    #1742
    jubei
    jubei [OP] would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
  3. Nov 2, 2018 at 11:08 AM
    #1743
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I don’t know what all the fuss is about. Jason sold me the crawler a month ago. Raped me on shipping though.
    jubei[QUOTED][OP] likes this.
  4. Nov 2, 2018 at 1:43 PM
    #1744
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Jason did say he was looking into Solo’s XLT kit.
  5. Nov 3, 2018 at 7:48 AM
    #1745
    jubei
    NoCo
    Stuff. Also things.
    I did?!
  6. Nov 3, 2018 at 7:53 AM
    #1746
    jubei
    NoCo
    Stuff. Also things.
    Do any of you knuckleheads know if I can use SPC UCAs with the TC coil bucket gussets?
    I know the SPC bushings are set up a little different than the typical TC or Camburg arms.
    I’m asking because I’ll be tearing into the front end soon and I’ll be gusseting cam tabs and possibly spindles as part of that. I’d like to gusset all the things while it’s torn apart, but not if the SPCs won’t play nice.
  7. Nov 3, 2018 at 7:57 AM
    #1747
    jubei
    NoCo
    Stuff. Also things.
    Forgot to tag y’all...
    @Reh5108 @Squeaky Penguin @Blackdawg @TMFF
  8. Nov 3, 2018 at 11:21 AM
    #1748
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not sure. What do the SPC arms use for bushings?
  9. Nov 3, 2018 at 11:43 AM
    #1749
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    :D Jk
  10. Nov 3, 2018 at 4:17 PM
    #1750
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    jubei[OP] likes this.
  11. Nov 4, 2018 at 5:51 PM
    #1751
    jubei
    NoCo
    Stuff. Also things.
    Biggest difference appears to be that they only use a washer at the outboard locations rather than both sides of each bushing.
    The TC gussets have you omit the outboard washers, so it looks to me like the SPC arms should be compatible. I’ll take some critical dimensions from my current AP arms and compare them to the SPCs that I have on the shelf in the garage. I think it’ll be fine, though.
    :p
    Thanks, Ryan.
    That’s exactly what I was hoping to see. It looks to me like just the one washer on the outboard side, right? The coil bucket gussets omit that washer, so I think I’m good to go.
  12. Nov 9, 2018 at 3:43 PM
    #1752
    jubei
    NoCo
    Stuff. Also things.
  13. Nov 10, 2018 at 5:19 PM
    #1753
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I hope you don't mind if I move this here. I din't want to clutter the daily with all my questions.
    I like the idea of using a whip but unsure about tuning it. I've always gone with adjustable tip antennas for that reason. You said that you got a pretty good SWR in the middle of the band, did you have to do anything to the antenna to get that? Trim the length?
    Also curious about the whipping action. How flexable is it? Does it bend back towards the windshield from the wind when on the interstate? What happens when it gets hit with a tree branch? I presume there is no spring on the base like we usually do with a traditional CB antenna like a firestik.
  14. Nov 10, 2018 at 6:24 PM
    #1754
    jubei
    NoCo
    Stuff. Also things.
    No problem, Mike.
    I did have to tune the antenna, but it was a piece of cake. I took SWR measurements at the band edges and the mid-band before and during the trimming, and just slowly walked in to it. I think I cut 1/8” each time. I did notice that the bandwidth slightly decreased as the antenna was tuned up in frequency, but that’s to be expected. I ended up with 1.05 at the mid-band and 1.4 at the low and high channels. I had no problems making comms with the guys last year at Rock Therapy with pretty decent separation at times.
    The flexibility is near perfect, in my opinion. It bends back a bit at speed, but it’s been great on tight trails with a lot of trees.
    I also really like that I can take it off, hang it up, and cap the mount. So nice.
    Prayn4surf and Digiratus[QUOTED] like this.
  15. Nov 10, 2018 at 9:56 PM
    #1755
    Digiratus
    Roaming the PNW
    The RedHead
    Sounds great. I need to redo my system this winter. This sounds interesting. I might go this route. Thanks much for the feedback.
  16. Nov 11, 2018 at 5:34 AM
    #1756
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    :threadjacked: Sorry Jason I could of dropped this in Bretts thread. Since a lot of the main 1st gen guys I trust are in here. Looking into replacing my fuel pump. Which one should I go with? Don't know much about fuel stuff.
    https://www.urdusa.com/fuel-pumps/
  17. Nov 11, 2018 at 9:35 AM
    #1757
    Digiratus
    Roaming the PNW
    The RedHead
    I recall Zane had some thoughts on this and was critical of the popular walbros. I cannot remember which one he ended up going with. @Speedytech7
    SilverGhost[QUOTED] likes this.
  18. Nov 11, 2018 at 9:48 AM
    #1758
    jubei
    NoCo
    Stuff. Also things.
    Shit, Ray, you’re always welcome in here!
    I seem to remember that as well, Mike.
    I haven’t had to mess with mine (yet), and all I really know about the fuel pumps for these trucks is that you need a higher flow rate pump for boosted applications. And like Mike said, I’ve heard that the Walbros can be kinda wonky, especially the noise that it makes. @eon_blue has a Walbro, maybe he can chime in.
    Are you looking ahead to an SC, Ray, or is this part of your fix for the misfire? I know you said that changing the plugs helped a lot with that.
  19. Nov 11, 2018 at 10:00 AM
    #1759
    eon_blue
    Azusa, CA
    Yeah I have a Walboro 190 pump installed that came with the URD 7th injector kit. A few months after install, I noticed that it likes to whine when it gets hot...and it can get super loud at times to where I can hear the whine while driving on the freeway with the windows up. That's an extreme example and it's not always like that, usually it's pretty quiet minus the typical "hiss" of a working pump. But the whining can be concerning sometimes...although mine's done it almost since day one and I've had it on for 1.5 years.
    If I were to do it again, Id get a different pump from AEM or Aeromotive like what @Speedytech7 recommended in another thread. Walboros have been around a long time but they're known to be noisy and not so reliable in some cases.
  20. Nov 11, 2018 at 10:04 AM
    #1760
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Both. I was planning on replacing the pump for the SC later on since I’m installing a fuel cell. But after talking to Brian and Tim last night about my pump getting old and could be part of my loss of power. Maybe it’s time now to consider upgrading the pump. Pretty much searching for what others recommend for a better pump.
