Runaway tacoma i can't believe it!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nelztaco, Nov 13, 2009.
  1. Nov 13, 2009 at 9:41 PM
    nelztaco
    nelztaco [OP] Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    I just can't believe it actually happened to me! I was driving to work this afternoon and I went to make an aggressive pass around a vehicle in the left lane and it happened! The truck down shifted & was pulling high revs & the accelerator pedal got stuck on wide open throttle! First I tried to hit the brakes & that didn't do a whole lot then I tried to tap on the accelerator to see if that would free it no luck so I hooked my foot under it and was able to pull it up. When I first heard about this I told my wife that it was a bull-sh** problem. So I zip-tied the mat & put it back in. Apparently it's not tied back far enough. I can definitely see how in a panic situation on smaller streets this could get ugly. I was on the interstate with an open lane in front of me. Called the dealer & Toyota. I have an appointment for tomorrow afternoon to remedy & put the wife at-ease.
  2. Nov 13, 2009 at 9:48 PM
    RAD
    RAD RAD Vendor
    THE RAD
    Socal
    2007 | TRD |1ST 2012+ CONVERSION
    2012 CONVERSION | A LOT OF TOTAL CHAOS & ICON DYNAMICS
    Wow man. I'm glad you're ok. I honestly think its B.S too but like you said. It can happen to you. That goes with everything in life. Its not bad until it happens to you or someone you love.
    Glad you're ok. Jump on the Dealership to do something. I'd be pissed a 30K truck almost killed me.
  3. Nov 13, 2009 at 9:50 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Glad you're ok man, that's the thing!
  4. Nov 13, 2009 at 9:50 PM
    TRDSport2006
    TRDSport2006 Well-Known Member
    Los Angeles
    02 Corolla
    Glad to hear you're okay. Sort of scares me that it's starting to happen here in TW. Maybe the problem is growing as the time passes. Has anyone else experienced this problem yet?
  5. Nov 13, 2009 at 10:01 PM
    nelztaco
    Neil
    Levittown, PA
    Thanx for the well-wishes. I will try to take pictures of the mat & accelerator pedal & try to recreate the pedal getting stuck without the engine running tomorrow just to see if it will do it again. And I will up-date tomorrow afternoon what the remedy from the dealer will be. Maybe they can retrieve the event from the computer to verify what all happened.
  6. Nov 13, 2009 at 10:08 PM
    SoCalBlack08
    SoCalBlack08 Well-Known Member
    CA
    08 PreRunner DC
    good thing your ok!
    what is toyota doing about this?
  7. Nov 13, 2009 at 10:14 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    lol @ zip ties
    as cmack48 states, husky liners bitches! ftw!
  8. Nov 13, 2009 at 10:27 PM
    NMG
    NMG Well-Known Member
    Ottawa
    09 Double Cab TRD Sport
    I've got the Toyota all weather mats and with them mounted properly with the hooks, I can't see any way that the pedal could get caught on the mat. I remember having a look at it when the stuck pedal thing first came out and the "cut-out" part of the mat where the pedal sits looks plenty big enough with lots of space around it.
    Are you using the hooks?
  9. Nov 14, 2009 at 1:20 AM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I heard that it's a computer problem. The accelerator pedal no longer works by cable, that's old school, now they call it drive by wire, the computer controls it and the computer is f-ing up. I can't remember they reason, but bottom line it's not the mat.
  10. Nov 14, 2009 at 2:54 AM
    dimitrik
    dimitrik Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    Easy way to fix this problem. Get manual. har har!
    Seriously tho i will try and replicate that with the mats toyota sold me. Should be interesting.
  11. Nov 14, 2009 at 3:03 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    My accelerator pedal hasnt gotten stuck in cases previously mentioned. It has, however, happened when I use cruise control (and it happens at least once every trip) . Ill set my speed and drive for a while and decide I wanna speed up so I use the cruise control lever/controls to increase my speed and it wont stop speeding up at which point I usually have to cancel the cruise control mode. It works perfectly fine when Im coasting in cruise, but when I start hitting the lever up to increase speed, it wont stop increasing it. Pretty scary the first time I experienced it, Now I just look out for it and cancel cruise control when it occurs. Ill have to take it in to Toyota when I go to get my radio TSB done.
  12. Nov 14, 2009 at 3:06 AM
    4X4_TRD
    4X4_TRD Well-Known Member
    Justin
    San Diego, CA
    '03 Jeep RUBICON
    No front sway bar (does that count?)
    I have read that the only thing they're going to do for you is remove the driver side floormat until they find a remedy for this.
    Good job staying on your game and finding a solution when it got stuck.
  13. Nov 14, 2009 at 5:25 AM
    george3
    new jersey
    tacoma
    I got a manual and didn't even know why until now ! Thanks :D
  14. Nov 14, 2009 at 5:33 AM
    BigAndy21966
    BigAndy21966 Well-Known Member
    Racoon City
    Wifeys build 2004 Tacoma TRD
    2.5" Toytec lift Cobra 148 SSB CB radio Soon: Snorkle, grey wire mod
    It happend to me a few years ago but I just wrote it up as a lazy dumbass that didnt put the mats back in the right way.
  15. Nov 14, 2009 at 5:53 AM
    nelztaco
    Neil
    Levittown, PA
    I have the facrory carpet mats & I stopped using the hooks when I decided to zip-tie the mat to the seat.
  16. Nov 14, 2009 at 5:55 AM
    tomonian77
    tomonian77 Well-Known Member
    Thomas
    Magnolia, TX
    2008 PR DC 4.0
    Painted Rims Black, Painted Emblems Black, Aftermarket Stereo, Grillcraft, BHLM, K&N CAI
    Happened to me in November of last year. Rolled the truck, thank god I was going so slow when it happened so it only rolled once and hit a dirt pile. Gulf States Toyota replace the throttle body, ecu, and accelerator assembly, no problems since that happened.
  17. Nov 14, 2009 at 6:28 AM
    nermalgod
    nermalgod Well-Known Member
    Bend, OR
    Offroad boat hauler
    Not going to brag.
  18. Nov 14, 2009 at 6:32 AM
    Agent7
    Agent7 Senior Executive of Nothing.
    Toronto, Canada
    07 Tacoma TRD Sport 4x4 6spd
    BHLM, Stubby Antenna, Custom Front Grill, Debaged Tailgate, Added TRD Emblem, Removed Factory Pinstripes, Leer 100XL Cap, Prolumen 6000K HID Kit with custom glare shields, Eurolite Yellow fog lights, 20" Fast Hustler wheels (black w/3" deepdish polished lip), Cooper Zeon LTZ 275/60/20's, Spidertrax 1.25" Wheel Spacers, Custom LED Gauges, Pioneer AVIC F700BT All-In-One Indash Navigation (Hacked)
    I wonder if it has anything to do with the angle of the accelerator pedal... ?
  19. Nov 14, 2009 at 6:34 AM
    nelztaco
    Neil
    Levittown, PA
  20. Nov 14, 2009 at 6:44 AM
    Ground-FX
    Ground-FX New Member
    Q
    Northeast
    09 TRD Sport Manual SB
    Im just wondering,could it be the cruise control location?I have a 2010 corolla recently bought and the on/off switch to the CC is in a position that can easily be switched on by accident without noticing unless you look in the instrument cluster.It may keep the revs steady but will not increase though.
