Running 12V to bed - best practices?
Discussion in 'Technical Chat' started by tamer, Oct 22, 2020.
  1. Oct 22, 2020 at 5:05 PM
    tamer
    tamer [OP] hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    I'm going to be running 12V to the bed, I intend to use 4AWG to the fuse panel in the bed. I've seen some people run a power and ground all the way to the rear and some just run the power, then make a short ground to the frame in the rear.
    I assume best practice is having the ground loopback all the way to the front?
  2. Oct 23, 2020 at 12:22 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I run an extra ground from the battery to the frame giving me a good ground at the frame anyplace.
    Being your project if you want to run the extra wire go for it
    Either way works
  3. Oct 23, 2020 at 1:43 PM
    MR5X5
    MR5X5 Well-Known Member
    To the frame locally is fine, then the frame is your "wire" back to the front of the truck.
  4. Oct 25, 2020 at 8:20 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    frame ground s o m etimes corrode become HIGH Resitant to voltage
    usually Unseen & difficult to detect
    run the BEST largest wire the length to avoid Any issues in the future
    no less use a wiring loom to protect from chafing against other wiring & frame
    natural strumming/vibrations going down the road
    attach with zip ties .......snug Not overly tight min 12inches.....max 18inches
  5. Dec 9, 2020 at 5:46 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    "It depends on the application," the man says, tapping the hourly consultation sign.
    4AWG pure copper is nominally good for up to 60A, and there are plenty of things in the neighborhood of 720W (60A @ 12V) and up that chassis ground. Personally, I would run a separate ground wire for anything electronic as opposed to electric (does it have complex circuits in it as opposed to something like lights), but only because I've been pissed off by inexplicably bad chassis grounds before.
    For higher power applications like a winch (which I assume is not the case here, as you are using 4AWG) I would use a separate ground wire.
  6. Dec 10, 2020 at 7:51 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I needed some power in the bed for a canopy mounted LED light. I ran a small wire from the positive battery post along the frame to the left taillight housing. I used plastic sheathing, zips and added a 10 amp fuse inline near the battery.
    Since it was just a little LED domelight, I just grounded right to a small bolt near the taillight. If you want to run something with a higher load then more consideration for fuse/wire gauge/ground selection would be needed
  7. Dec 10, 2020 at 8:02 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The *best* would be a wire back to the battery for ground, but you can probably get away with grounding to the frame. I like knowing the entire path of the current when I add a new circuit, so I would run the extra wire.
    Make sure to put a breaker or fuse for the whole thing as close to the battery as you can manage as well.
  8. Dec 10, 2020 at 8:06 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Not sure if OP is still around but it an OR should have that power outlet in the bed. Might poke around there and see if you can tap into some power, should a be a good ground point in there.
    Cant remember if that power outlet is only key on or all the time though
