Running 35's on stock 97 Tacoma ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yota4life97, Jan 2, 2016.
  1. Jan 2, 2016 at 10:37 PM
    #61
    96_taco
    96_taco Well-Known Member
    Clayton sandgren
    Northern va
    1996 Tacoma 2.7 4x4 extended cab
    33" bfg mud terrains, cold air intake, flowmaster with side exhaust, manual swapped, manual hub swapped, lifted on bilsteins
    Just search the truck over. Make sure there's no broken links, if you can get it in the air and make sure all 4 tires have zero side to side and up and down play, go through and grease all grease able joints, basically just look for stuff that's wrong. Literally try to find stuff wrong with it or stuff that doesn't look right
  2. Jan 2, 2016 at 10:39 PM
    #62
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    If moneys not a problem then do it right the first time with a uca and coilover lift. Fox, icon, and king are popular brands. Try not to crank them above 3". For the rear go with a new leaf pack. That will depend on what you plan on doing with the truck. 2.0 shocks are available for factory rear locations or you can do a shock relocation.
    Get a set of 33s of your choice. Remove the coilover and cycle the suspension with tire mounted. Trim where necessary.
  3. Jan 2, 2016 at 10:40 PM
    #63
    Yota4life97
    Yota4life97 [OP] Well-Known Member
    Sean
    97 Tacoma 5speed 4x4
    Well I don't know wrong from right on trucks but the guy I have working on my truck does I'll tell him to go over the stuff you just listed
  4. Jan 2, 2016 at 10:42 PM
    #64
    Yota4life97
    Sean
    I'm not sure what this stuff means but I'm writing all this down to show my mechanic
  5. Jan 2, 2016 at 10:42 PM
    #65
    GingerJoe
    GingerJoe Well-Known Member
    Joe
    Ames, IA
    06 Red 4 Banger 5 Speed
    33" tars
    Then don't jump to spending tons of money on a bunch of crap, learn about your truck and the products that would benefit your truck first.
  6. Jan 2, 2016 at 10:43 PM
    #66
    96_taco
    Clayton sandgren
    Northern va
    What's uca mean/stand for?
  7. Jan 2, 2016 at 10:43 PM
    #67
    GingerJoe
    Joe
    Ames, IA
    33" tars
    Upper Control Arm
  8. Jan 2, 2016 at 10:44 PM
    #68
    96_taco
    Clayton sandgren
    Northern va
    Ooooohhhhhhh makes sense now lmao thanks
  9. Jan 2, 2016 at 10:44 PM
    #69
    devinzz1
    devin
    2023 aclb trd or mt
    Upper control arm. Above 2.5" the alignment runs out with the stocker and the ball joint is almost maxed.
  10. Jan 2, 2016 at 10:46 PM
    #70
    96_taco
    Clayton sandgren
    Northern va
    Yeah I know what you mean, mines at 2.5 now with stock control arms/ knuckles and my knuckle is close to hitting the actual coil at full extension
  11. Jan 2, 2016 at 10:49 PM
    #71
    GingerJoe
    Joe
    Ames, IA
    33" tars
    I would look into investing in a new set of UCAs, total chaos UCAs is a pretty popular choice among Tacoma owners
  12. Jan 2, 2016 at 10:50 PM
    #72
    96_taco
    Clayton sandgren
    Northern va
    Yeah I might, currently on my plate is a w59 swap to get rid of my auto and also trying to build an f250 at the same time
  13. Jan 2, 2016 at 10:52 PM
    #73
    Yota4life97
    Sean
    I appreciate everyone's advice thank you guys!
  14. Jan 2, 2016 at 10:54 PM
    #74
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The 3.4 is non interference so it'll just stop running if it breaks, but you are right it is better to just replace it before the towing bill.
  15. Jan 2, 2016 at 11:02 PM
    #75
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    30 viewers and nearly 5 pages in less than 2 hours, all over a 5 inch lift that cant even get paid for. Sheesh.
  16. Jan 2, 2016 at 11:06 PM
    #76
    Yota4life97
    Sean
    That was real immature ya know just gotta keep jabbin me with the stupid money deal thanks again
  17. Jan 2, 2016 at 11:09 PM
    #77
    Caligula
    Los Angeles, CA
    It does need to keep being brought up as its the last thing you should be thinking about.
    Part of me still thinks this thread is might be fake though. Its just too perfect.
  18. Jan 2, 2016 at 11:19 PM
    #78
    Yota4life97
    Sean
    How is it fake and the truck is the first thing to be thinking about because if I don't have it then I ain't getting to school gotta ride in style
  19. Jan 2, 2016 at 11:19 PM
    #79
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Lmao. Good read.
  20. Jan 2, 2016 at 11:21 PM
    #80
    Caligula
    Los Angeles, CA
    I know, right?
    jmaack[QUOTED] likes this.
