Running a CO2 in tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Featuring_Kev, Mar 15, 2021.
  1. Mar 15, 2021 at 5:55 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Dude. Even my mother in law knows the difference between carbon dioxide and nitrogen. Cmon man.
  2. Mar 15, 2021 at 5:56 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    If you’re limited on space and can deal with re-filling them. Then they are a very decent option and you’ll have no adverse effects. As for manufacturers, it’s a tank they are all the same really, it’s the regulation you need to be concerned about, build your own IMO.
    I have a hard enough time keeping my grills propane and my mig welding tanks full, fuck dealing with that on tires as well. Compressor is my tool of choice, as while it’s slower, it never runs out. But co2 tanks are a good option for off-roading and airing up on the trail. I personally would never use them for garage use.
  3. Mar 15, 2021 at 5:57 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    Too bad she didn't mention to you that CO2 is a perfectly fine solution. Hell, if you'd even read the thread you'd have saved yourself some embarrassment before you decided to chime in.
    JNG, Snaeper, davidstacoma and 2 others like this.
  4. Mar 15, 2021 at 5:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yes. It is. Guess what... Air works good too. It compresses just like the other gases. You guys buy into too much marketing hype.
    Nitrogen is good... in race car tires.
    CO2 is like the poop of gases.
  5. Mar 15, 2021 at 5:59 PM
    kairo
    kairo >_>
    Nor Nev
    Dude, you can't pressurize a tank with air and expect it to fill up tires. Stop posting misinformation. You have no idea what you're talking about.
    Tttacodan and Snaeper like this.
  6. Mar 15, 2021 at 5:59 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Nitrogen is snake oil unless you’re a NASCAR driver...
    I actually stopped going to my last mechanic because he kept trying to push it on me!
  7. Mar 15, 2021 at 5:59 PM
    PennSilverTaco
    Charlie
    This ^^^^
  8. Mar 15, 2021 at 6:00 PM
    kairo
    kairo >_>
    Nor Nev
    No.
    Go get a scuba tank and see how many tires it fills up. Hint: not very many.
  9. Mar 15, 2021 at 6:00 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol embarrassment. CO2 why.
  10. Mar 15, 2021 at 6:00 PM
    mutely
    You can use either for tires. One is for stability (nitrogen), other is for speed and portability (CO2)
  11. Mar 15, 2021 at 6:00 PM
    kairo
    kairo >_>
    Nor Nev
    Not sure if you're trolling or just super ignorant. Ah well.
    Snaeper likes this.
  12. Mar 15, 2021 at 6:01 PM
    PennSilverTaco
    Charlie
    Like I said, I stopped going to one mechanic because he kept trying to push nitrogen on me; My current mechanic says it’s snake oil...
  13. Mar 15, 2021 at 6:02 PM
    kairo
    kairo >_>
    Nor Nev
    Scuba tanks aren't filled with nitrogen unless you're using NITROX for deep diving. Nitrox and nitrogen and compressed air are all different things... We weren't talking about nitrogen. Some dude up the line said compressed air in a tank was as good as C02. And that's objectively false
    Snaeper likes this.
  14. Mar 15, 2021 at 6:05 PM
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    ...after reading all the comments to this point... I am curious to know someone else's experience experimenting with inflating their tires using Helium...
  15. Mar 15, 2021 at 6:05 PM
    #35
    PennSilverTaco
    Charlie
    Someone else mentioned nitrogen and that’s what got my attention; I see no point in putting anything but air in my tires...
  16. Mar 15, 2021 at 6:08 PM
    #36
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yes you can. Is google mad at you?
    Again, hype. I have a 20 lb air tank air tank and it fills up four tires nicely.
  17. Mar 15, 2021 at 6:09 PM
    #37
    PennSilverTaco
    Charlie
  18. Mar 15, 2021 at 6:10 PM
    #38
    kairo
    kairo >_>
    Nor Nev
    lol. No, you don't. Unless you can provide some sort of proof, there's no way you're getting any useful service out of a regular 20lb tank filled with compressed air. You filling up go kart tires?
    Edit: I think I just figured out what you meant. 20 GALLON air tank, like on a home compressor.
  19. Mar 15, 2021 at 6:11 PM
    #39
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    I use a special secret blend of 78% nitrogen, 21% oxygen, and a pinch of argon cause I like the way it sounds in the rain.
  20. Mar 15, 2021 at 6:13 PM
    #40
    mutely
    A full side scuba tank will do quite a lot of 35” tires. These C02 tanks can go up to something like ~3000psi where you normal air tank is 120psi. So a 5lb tank (smallest) at like 1000psi can fill up 4 35” tires from 0psi to 35psi, and probably ~10 “air-ups” from 15psi to 35psi. None of the numbers above are exact, just approximate. So a scuba tank is something like 20lbs would do 4x the numbers above.
    davidstacoma likes this.
