Running a hitch through a steel bumper?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomagal101, Oct 12, 2021.
  1. Oct 12, 2021 at 3:01 PM
    tacomagal101
    tacomagal101 [OP] Active Member
    Yanis
    2018 Tacoma
    I was wondering if you could run a hitch through a steel bumper (Hooke road brand) on a 2018 Tacoma…also, is the hitch connected to the factory bumper?
  2. Oct 12, 2021 at 3:11 PM
    zDirtyDeedz
    zDirtyDeedz @FlatironsOverland
    Dylan
    Boulder, CO
    '19 White DCSB
    Not familiar with that brand but a quick Google search on the product shows it works with the original receiver hitch. The hitch is separate from the factory plastic bumper.
    G4204 2016-2021 Toyota Tacoma Gen 3 HR Rear Bumper w/License Plate Bracket
    Fit for 2016-2021 Toyota Tacoma 3rd Gen Models
    Bumper Weight: About 53 lbs
    Heavy Duty 11-Gauge(1/8 Inch) Maximum Steel Construction
    Textured Black Powder Coat Finish
    One-Piece, Fully-Welded Structure
    Works with Factory Receiver Hitches
    Compatible with Factory Back-Up Sensors. Pre-Drilled Holes for Sensors to Fit Properly. Professional Installation Is Recommended
    License Plate Mounting Bracket Included; Pre-Formed Cut-Outs to Accommodate Factory License Plate Lights
    Rear Bumper Provides Adequate Front-End Protection
    Integrated Corner Side Steps for Convenient Truck Bed Access
    Premium E-Coating Process for 5-Year Corrosion Protection under Normal Use
    Simple Bolt-On Installation w/Detailed Instruction; No Cutting Required to Install
    2 Year Limited Manufacturer Warranty & Lifetime Customer Support
    tacomagal101[OP] likes this.
  3. Oct 12, 2021 at 4:43 PM
    NorNev
    NorNev Phone? Call someone who gives a shit.
    Dave
    39° 31′ 6″ N, 119° 59′ 19″ W
    KDMAX Tuned 17 2•2X2•2 Hood Scoop
    A Few
    Welcome to TW :thumbsup:
  4. Oct 12, 2021 at 4:53 PM
    MaxKrax
    MaxKrax Well-Known Member
    Kris
    Sparks, NV
    2021 Cement Tacoma TRD Sport
    RCI Skid plate RCI bed rack Roofnest RTT Baja Designs Squadron Pro yellow fog lights
    Yes, I've seen several high clearance bumpers used with an integrated hitch, usually where the license plate currently sits. You fold the license plate down to access the hitch. Then you cut the OEM hitch off
    tacomagal101[OP] and gudujarlson like this.
  5. Oct 12, 2021 at 5:07 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Do you have to cut the OEM hitch off or is it bolt on?
  6. Oct 12, 2021 at 5:09 PM
    gudujarlson
    Minnesota
    OP, I’m pretty sure the OEM bumper and hitch are separate. To be sure, there are high clearance bumper install videos on YouTube. I plan to install a high clearance rear bumper with a hidden hitch receiver in the not too distant future. It improves the rear approach angle by a fair amount.
  7. Oct 12, 2021 at 5:09 PM
    MaxKrax
    Kris
    Sparks, NV
    Honestly I haven't gotten down and looked, but generally hitches are welded on
  8. Oct 12, 2021 at 5:11 PM
    gudujarlson
    Minnesota
    I’ve assumed it’s bolted on, but I have not looked myself either.
  9. Oct 12, 2021 at 5:15 PM
    zDirtyDeedz
    Dylan
    Boulder, CO
    '19 White DCSB
    Definitely bolted on. Definitely can be used with aftermarket rear bumpers if they're designed for it. Definitely good to buy that bumper but I can't attest to the brand and quality.
  10. Oct 12, 2021 at 5:20 PM
    NorNev
    Dave
    A Few
    Factory, at least on my 17 are welded to the frame
  11. Oct 12, 2021 at 5:44 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Factory hitches are bolted on. Most of the non-hc bumpers just replace the stock bumper, and retain the stock hitch. Most high clearence bumpers get rid of the stock hitch.
    My Coastal hc has a hitch recessed into it. Only downfall is you need a huge drop hitch, but not too big of a problem.
    Here you can see the hitch slot above the piece of wood, its probably 4-5" higher than stock
    Back to your original question, the Hooke bumper bolts on and leaves your stock hitch.
  12. Oct 12, 2021 at 5:49 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    100% not true unless you have some kind of aftermarket deal. OEM Toyota tow package hitches bolt to the frame.
    imagine what a headache it would be at the factory if they had different frames for hitch and no hitch?
  13. Oct 12, 2021 at 6:11 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    funny how that picture still looks safer than a high-lift jack
  14. Oct 12, 2021 at 6:24 PM
    zDirtyDeedz
    Dylan
    Boulder, CO
    '19 White DCSB
    :rofl:It's funny cause it's true
  15. Oct 12, 2021 at 7:56 PM
    rpowell25
    rpowell25 Well-Known Member
    Robert
    Walnut Creek, Ca
    2019 Tacoma DCSB TRD Off Road 4wd
    The list is long but distinguished
    Can confirm factory hitch is bolt on. Here's a BAMF HC rear bumper with the hitch behind the plate.
    MwyY3IgLJ7eskTg4VU6uAsnBe4cPvd9cmgqYIA_D_b43647b57b9049ef40425b2d983e42302d72537f.jpg V31yflf9MFgVsY7v5kxwG_-msgrdUuSxD89fCiB7_362fb8d16052e1420724e9b549e9b1d98ac62f9f.jpg zNYkAhYNyFr_dhRO24rHuW3BKHopstdKOUedgX7S_cde243d1e3a22d7f0099ebc71922ea2ee30a3202.jpg
  16. Oct 13, 2021 at 5:07 AM
    NorNev
    Dave
    A Few
    I stand corrected
  17. Oct 13, 2021 at 5:27 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    In my 30 years of experience, the only receiver hitches that I have seen that were welded on, were the ones that broke off. All other hitches were bolted on.
