Running a r16 wheel as a spare on sport with r17's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cro, Oct 3, 2012.
  1. Oct 3, 2012 at 4:42 PM
    cro
    cro [OP] Member
    Nor Cal
    sport 4x4 trd
    Hi everyone , longtime reader first real post. I have been searching and searching so I didnt have to ask but no luck.
    Question: Does anyone see a problem running a spare 265/75 r16 on a TRD sport with 265/70 r17 wheels ? according to the tire calculator there is only a very small difference in the 2. Anyone doing this or have any experience with this ?
    I ask because it seems like single 265/75 r16 are easier to come by than a single 265/70 r17.
    Thanks
  2. Oct 3, 2012 at 5:05 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    your spare tire is mounted on a 16inch rim?
    should be ok if you only plan on doing it in the event you need a spare and not run the spare permanently
  3. Oct 3, 2012 at 5:06 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Not an issue.
  4. Oct 3, 2012 at 5:10 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Just run it in the rear.
  5. Oct 3, 2012 at 5:12 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    Ehh...not really since he has a mechanical LSD in the rear.
  6. Oct 3, 2012 at 5:18 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yeah, what jhodge said...
    It won't be an issue since the tire sizes are the same but if you have to run different sized tires on a vehicle with limited slip, you don't want to run them on the axle with the mechanical limited slip. It can cause some issues while driving.
  7. Oct 3, 2012 at 5:28 PM
    cro
    cro [OP] Member
    Nor Cal
    sport 4x4 trd
    thanks guys , Yeah am fully aware of running different size tires with LSD , lockers etc,
    but as 265/75 r16 is so close to 265/70 r17 I was thinking there would be no issue.
    cheers
  8. Oct 3, 2012 at 5:30 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    You will have 0.04" difference, there should be no problem.
  9. Oct 3, 2012 at 5:31 PM
    The_Hodge
    SC
    There shouldn't be an issue since they are that close, just clearing up the general rule.
  10. Oct 3, 2012 at 6:31 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Good catch, was typing fast on my phone and that came out terrible. Meant to say be careful if running in the rear. I wouldn't recommend using it for an extended period of time. Thanks for the correction. :thumbsup:
