Running a wire to fuse box
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoWI, Mar 9, 2021.
  1. Mar 29, 2021 at 4:58 PM
    #41
    Geronimo1111
    Geronimo1111 Well-Known Member
    Ventura, Flagstaff & Phoenix
    '07 Silver Streak Mica 2.7L AC
    Ride-Rites LEER 100 XQ Cap Homemade Bedslider Bilsteins
    @JdevTac I'm going to check now...
    Will the wires on driver and passenger side tuck behind the plastic trim? I'm assuming the trim gets removed and the wires tucked in there?
  2. Mar 29, 2021 at 5:18 PM
    #42
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    That’s the best/cleanest, and most protected way to run it, yes. Pull the door sill trim panels. Pull the dead pedal and kick panel and run your wires to the rear.
    If you aren’t running to like a fuse panel or something inside the cab, the easier way is just skip going into the cab and run your wires from the engine bay straight to the bed. I run the wire inside of a protective wire loom, usually follow the OEM hard lines exiting the engine bay and joining the frame on the driver side. Stay as far away from cat converters as possible, and then run wire along frame rail, zip tying the wire as you go until you get to the bed.
    Geronimo1111[QUOTED] likes this.
  3. Mar 29, 2021 at 5:40 PM
    #43
    Geronimo1111
    I'm not going to a fuse panel in the cab...so, I could do as you suggest and skip going through the cab...that was my first choice, but I didn't see anyplace that I was sure would be ok to run the wire/loom...
    Looks like there are three hard lines clipped into a white plastic mount...wasn't sure what those were and didn't know if it was ok to tie the loom to those...I'll see if I can get a picture....
    Looks like there is a little nipple on the large driver's side grommet for additional wiring to run through as well as the smaller grommets behind, I'm assuming, the brake booster and then a similar one on the passenger side....I'll post pics of those now...
    Large wiring grommet
    Small grommet (behind brake booster?)
    Small grommet - passenger side
    Does this plastic piece holding the trim just pop off...or does it have to be screwed off?
    Grommet underside of passenger seat (exterior)
    Grommet under passenger seat (inside)
  4. Mar 29, 2021 at 5:43 PM
    #44
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Do this:
    Geronimo1111 likes this.
  5. Mar 29, 2021 at 5:47 PM
    #45
    Geronimo1111
    Thanks @Cudgel I think I see a red and black wire going behind that bracket on the side wall, but I can't see where they go from there...
  6. Mar 29, 2021 at 6:04 PM
    #46
    Geronimo1111
    @JdevTac I'll post pics of what I think you are referring to...
  7. Mar 29, 2021 at 6:36 PM
    #47
    JdevTac
    Josh
    MD/GA
    2nd gen
    Yes those small grommets are the ones I was referring to.
    for the kick panel you first must remove the door sill trim piece. Just pull upward with your hands working your way center to edges, then remove the dead pedal first with a careful but firm pull straight toward you. Then unscrew the little black retention screw, and the kick panel pops off.
    Yeah those hard lines is what I refer to. I have run my wire in tandem with them, in a nice wire loom for extra protection. On my vehicle there was an unused position on the hardline plastic clip that I put my wire in. I ran down to frame and snaked wire away from the cats. There was a hole behind the fender splash guard just before reaching the frame that I used to ziptie the wire for added retention. I actually bought a thermal sleeve for the wire run there as well but I haven’t needed it. Snaking the wire along the frame from there is easy. Ziptie it along the way to other cables. I don’t like to ziptie to hard lines. How you get the wire into the bed is then up to you.
  8. Mar 29, 2021 at 6:37 PM
    #48
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Into the whiskey bottle holder for my second battery and isolated ham radio circuits.
  9. Mar 29, 2021 at 9:48 PM
    #49
    Geronimo1111
    Thanks for the direction on the paneling. :thumbsup:
    I think I saw that unused position on the hardline plastic clip...I didn't get your message until after I routed the cable along the firewall to the grommet on the passenger side. I got as far as cutting the nub off the grommet, using a utility knife to put an "x" opening in it and fishing the cable through. I'll post pics... wire loom and zip tied up.
    I think I threw another zip tie on in the engine compartment...and also fished the wire a little better on the inside after I took those last two pics.
    Tomorrow, I'm going to go back and route the cable to the grommet under the passenger seat, down the frame rail the to wheel well/storage cubby. :fingerscrossed: Thank you for your assistance!
    IMG_20210329_185128670.jpg IMG_20210329_185139994.jpg IMG_20210329_185154821.jpg Wire inside cab - passenger side.jpg
