Running Board bolt sizes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stevedidj, Jun 13, 2008.
  1. Jun 13, 2008 at 12:40 PM
    stevedidj
    stevedidj [OP] Well-Known Member
    OK I've just purchased a set of factory running boards from a Tacoma owner who didn't want them. He did not provide the bolts. Does anyone know what size/length these bolts are? It's for a 2008 Tacoma Access Cab.
  2. Jun 13, 2008 at 12:56 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Have you checked the spots underneath where the boards bolt up? When I put my OEM nerf bars, I think I remember one spot where I had to remove a bolt (towards the front of the cab). The other spots had cover on the holes. Its worth a try.
  3. Jun 13, 2008 at 8:23 PM
    wcm608
    wcm608 Well-Known Member
    Pittsburgh, Pa
    08 DC LB 4x4 SR5 Impulse Red
    I just put on some Aries bars on a dbl cab but the bolts that attach to
    the rocker should be the same size. Aries uses 8mm x 30mm 1.25 pitch.
    Also 8mm flat washers and 8mm lock washers. Can't help you with the
    bolts to attach the bars to the brackets.
  4. Jun 14, 2008 at 12:00 AM
    shawnpdx
    shawnpdx New Member
    Just installed my Toyota running boards on my 08 access cab myself. The instruction sheet that came with it says you will need twelve M8x25 serrated flange screws. They looked like they had a bit of blue loctite on them as well.
    The 1/4-20 bolts that hold the brackets to the running board need to be loosened before installation to allow adjustment and then tightened to 8lb-ft when done. The M8x25's need to be torqued to 14.4lb-ft when done.
  5. Jun 14, 2008 at 7:49 AM
    stevedidj
    Thanks dudes - I bought the M8x25mm 1.25 thread bolts at Lowe's (amazingly good selection there of all kinds of automotive fasteners by the way) and put the running boards on. Worked great first time/piece of cake!
    z00mer, JETSPD and Blackout14 like this.
  6. Nov 6, 2017 at 12:49 PM
    Michael_Westen
    Michael_Westen Well-Known Member
    NC
    2018 Tacoma Double Cab TRD Off Road Inferno
    I have factory running boards on mine and I'm looking at taking off, what length bolt came out of the attachment points?
  7. Nov 6, 2017 at 12:50 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Holy shit man, this thread is almost a decade old.
    Edit: also the size was mentioned above. The bolt is 25mm long.
  8. Nov 6, 2017 at 1:19 PM
    Michael_Westen
    NC
    I'm just going to run some M8 x 16mm stainless bolts with stainless lock washers in the holes and call it a day.
