running boards
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bud, Dec 4, 2006.
  1. Dec 4, 2006 at 10:09 AM
    Bud
    Bud [OP] Member
    Does anybody have any feedback on the use of running boards that fit flush to the body vs tubular step bars?
  2. Dec 4, 2006 at 10:52 AM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Toyota sells a set that is a few millimeters from touching the body. The problem with running boards is that it will trap salt between the gaps if you are in snow country. This is not the case with nerf bars. If you are adventurous, you can modify the mounts to eliminate the space. A tight fit may be detrimental to your rocker panel. It may cut into your rocker panel over time hence the tolerance is needed.
  3. Feb 22, 2007 at 7:50 PM
    texastaco
    texastaco Member
    I have n-Fab bars on my 07' andam very pleased. Check them out on my truck (Texastaco). and no, i am a commercial contracor, nit a supplier or truck accessory supplier!
  4. Feb 23, 2007 at 6:50 PM
    Ldytaco05
    Ldytaco05 it's all about me
    Orlando, Fl.
    2005 PreRunner,Enkei Wheels
    mine came with the purchase :sorry:
  5. Aug 7, 2007 at 3:19 PM
    novella
    novella Member
    I just installed Factory running boards on my 2007 Tacoma. The part number for the ones I installed is PT212-35053. I also installed doorsill protectors at the same time, part number PT747-35051. Both these items are available from www.toyota-parts-dealer.com located in Virginia. They price the running boards for $247 and the doorsill protectors for $20. My Tacome X-cab was predrilled for the running boards which are held on by 6 bolts. These predrilled holes had plastic inserts to protect the holes. This installation took about twenty minutes. The doorsill protectors took longer because of sill cleaning necessary before installing the self adhesive doorsill protectors. I bought the black aluminum running boards instead of the tube type because I liked the look better, a matter of opinion. My truck is a basic Tacoma X-cab with only Option A.
  6. Sep 13, 2007 at 12:18 PM
    bradn88
    bradn88 Member
    do these stick out far enough to prevent door dings? also, is it made of that hard plastic material, similar to the bedliner?
  7. Sep 13, 2007 at 4:47 PM
    novella
    novella Member
    They do stick out enough to help prevent door dings. They seem to be made of coated aluminum.
  8. Sep 13, 2007 at 5:09 PM
    bradn88
    bradn88 Member
    i think what you have is different from that part number - i believe the ones i'm talking about are made out of a bedliner type hard plastic material.
  9. Sep 14, 2007 at 9:50 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I also have the stock running boards. They stop most door dings but not all! Some large vehicles have doors that bulge at the top that makes it defeat the boards. Still...it is better than nothing.
    Also, there is a rubber flap that is used between the board and the truck body. I think this just makes it look cleaner.
  10. Sep 14, 2007 at 9:58 AM
    bradn88
    bradn88 Member
    so are the stock ones from toyota aluminum or hard plastic?
  11. Sep 14, 2007 at 10:10 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    They're aluminum with some plastic caps on them. I'll have to check on the actual mounting hardware.
  12. Mar 24, 2016 at 3:57 AM
    AppStateTaco
    AppStateTaco I love Ice cream
    North Carolina
    16 Toyota Tacoma
    Just a quick question, hope it hasn't ever been discussed before because I don't want to be "that guy" but anyway will 1st gen NFAB bars fit a 2nd gen? Both are double cabs.
  13. Mar 24, 2016 at 4:57 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I'm also in snow country, but I don't find this to be the case. Mine are about 3/8" from the panels and nothing gets trapped in the gap.
