Running Boards
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacomakh, May 24, 2016.
  1. May 24, 2016 at 6:41 AM
    Tacomakh
    Tacomakh [OP] Member
    I just purchased a 2016 Tacoma that came with the Toyota black, cast aluminum running boards. While they look good, I am only 5'3 and the boards are so wide that I hit my calf every time that I get out of the car. They are also too tall to use comfortably as a step so are useless for that purschase. I do not think that I even need them but I like the looks of something there. Any suggestions on replacements that do not stick out quite as far?
  2. May 24, 2016 at 6:44 AM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
  3. May 24, 2016 at 6:47 AM
    Tacomakh
    Those are nice but quite pricey. I really like for them to show all of the time, just need something not quite as wide.
  4. May 24, 2016 at 6:48 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    I have the predator steps. They are dropped enough that you can use them as intended. Depends if you like the look. If you do a lot of off roading they can get caught on rocks.
  5. May 24, 2016 at 7:03 AM
    Tacomakh
    What about tubes steps? Do they stick out as far a the running boards?
  6. May 24, 2016 at 7:08 AM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    They don't stick out as far but they are just as high.
    WilderTaco likes this.
  7. May 24, 2016 at 7:12 AM
    Tacomakh
    That might work though. Believe it or not, I can get into the truck just fine with not steps. I just keep banging my calf. If I try to get in standing on the board, I have to be careful not to hit my head on the door frame. I am just going for looks.
  8. Oct 4, 2019 at 8:15 AM
    lsukevinc
    lsukevinc Well-Known Member
    Kevin
    2019 cement limited
    im having the same issue with the stainless steel ones that came with my truck. i may take them off soon. i'm 5-10 and i swear i have to stick my leg out all the way so i dont rub the steps getting out.IMG_5191.jpg
  9. Oct 4, 2019 at 8:51 AM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I have the black OEM tubes. Here’s the measurement from the puckered under-sill edge (Below.) They are rounded so don’t bruise you as much as the blockier ones. I don’t find them very useful, but I’m somewhat tall and have large boots that can barely find purchase. My kids use them, and the protect from dings in parking lots. Why don’t you pull your current ones off and see if you like it?
  10. Oct 4, 2019 at 8:58 AM
    su.b.rat
    su.b.rat broken truck
    another low cost option for aesthetics is to derp your pinch weld (plasti-dip the pinch weld running under the cab). it really cleans up the look and you may not feel you need a tube or step there since it's basically just a vanity panel you're looking for.
    you can see in the pic that i have sliders, but looking past that it's nice and clean from covering the pinch weld.
  11. Oct 4, 2019 at 9:00 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    take them off?
  12. Oct 4, 2019 at 9:13 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    That looks nice. I'm actually surprised at how much of a difference it makes.
    su.b.rat[QUOTED] and Malvolio like this.
  13. Oct 4, 2019 at 9:18 AM
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I think that looks really good. Is there something more durable than plasti-dip, though, like an engine enamel that will take small rock and sand and gravel hits better?
    su.b.rat likes this.
  14. Oct 4, 2019 at 9:29 AM
    su.b.rat
    paint? LineX? a number of options, but FYI i derped two years back and it's still perfect. no white paint showing through anywhere.
    Malvolio[QUOTED] likes this.
  15. Oct 4, 2019 at 9:30 AM
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Cool. Cool idea too.
  16. Oct 4, 2019 at 9:34 AM
    su.b.rat
    BTW i used the paint-on Plastidip for a nice thick coat (two actually), less mess & no overspray, and a little less volatile chems flying around me. although even the paint-on is pretty nasty stuff, hold your breath.
