Running Camburg UCAs w/ Dirt King LCAs, good or bad idea?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TrojanTaco_92, Jan 19, 2022.
  1. Jan 19, 2022 at 7:49 PM
    TrojanTaco_92
    TrojanTaco_92 [OP] Member
    J
    '21 Cement Taco DCLB
    Suspension:
    Front: 2.5 Fox w/ DSC 8-inch coil over
    Camburg 1.25 UCA
    Total chaos spindle gusset w/ sway bar mount
    stock tacoma lowers w/ RCI skid plates
    CMC
    Rear: 2.5 Fox rear res w/DSC
    Archive garage hammer hangers w/ cross tube
    Archive garage U-bolt flip kit
    Deaver J66
    Timbrens active bumpstops
    Hey guys, been running the Camburg 1.25 uniball performance UCAs for awhile, using the stock tacoma Lowers which has been a phenomenal set up for my needs, however want to get set up for adding bypass, and hydro bumpstops in the future (eventually going full long travel).
    I have saved enough to change out the stock lower, but not a big fan of the camburg LCA design/alignment/issues and more use of uni-ball joints.
    The Dirt King performance lower control arms, look more appealing in all aspects (moog-joints, $$$, a lil bit more ground clearance.
    However I am not sure if mixing brands uppers and lowers is generally a safe/practical idea, I.e. running Camburg uppers with Dirt King lowers, thoughts?
    Help a friend out, thanks much !
  2. Jan 19, 2022 at 8:52 PM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    In my opinion, you’re overthinking it if you’re concerned about safety by not matching brands, you’ve already got Tital chaos in the mix. Why not go upper and lower Total chaos?
  3. Jan 19, 2022 at 8:56 PM
    TrojanTaco_92
    J
    Just wondering, if it is common practice to be mismatching different brands of suspension kits, does it matter????
    I guess what I'm trying to say is not safety, but will I be running into technical issues if I use different brand UCAs and LCAs together?
