Running coax into cab
Discussion in 'Technical Chat' started by MikeS., Jun 19, 2008.
  1. Jun 19, 2008 at 6:25 PM
    MikeS.
    MikeS. [OP] Well-Known Member
    Far Eastern WVa
    2008 DC LB 4x4 in Speedway Blue.
    Undercover bed topper, Nerf style step bars, Python alarm, Ham radio with 250 watt amp and chrome wheel well bling.
    How/where do you radio guys run the antenna coax into the truck? I don't want to run through a window or door seal. Are there any grommets at or near the rear of an 08 DC?
    Any pics of where you have run it through?
    Thanks,
  2. Jun 19, 2008 at 7:08 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    there are 2 rubber grommets that u can pop through the firewall....besides that, u'd prolly have to hollow out one of the rubber pop ins under the cab and go through there
  3. Jun 19, 2008 at 7:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    There are a couple of rubber gromets on the underside of the truck. You can follow the frame right to them. One is under the left side of the driver seat. :)
  4. Jun 21, 2008 at 9:15 PM
    MikeS.
    Far Eastern WVa
    I wound up using a Wilson 5000 mag mount in the center of the cab roof. I ran the coax into the cab by way of the slider window.
  5. Jun 22, 2008 at 7:46 PM
    Punisher
    Punisher Billy Reuben
    Massachusetts
    2008 Access Cab TRD Off-Road
