Running different loads on an amp
Discussion in 'Audio & Video' started by Evil Monkey, Dec 3, 2009.
  1. Dec 3, 2009 at 1:04 PM
    Evil Monkey
    Evil Monkey [OP] There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Does it harm the amp to run two different impedance loads on multiple channels? My speakers are a 4-ohm load and the sub is a 2-ohm load (voice coils hooked up in parallel). Currently, I have a 4-channel amp with my driver and passenger speakers hooked up to create a 2 ohm load on the 2 front channels with the dual voice coil sub bridged on the 2 rear channels. If I disconnected the rear speakers, it would jump to a 4 ohm load on the front and a 2 ohm load on the back. I was also thinking about a 5 channel amp, but it would be the same issue.
    The amp I have now works but it shuts off if I turn it up too loud for too long with heavy bass (overheat protection?). I prefer one amp for simplicity's sake.
  2. Dec 3, 2009 at 1:58 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    What amp do you have? I'm guessing that your amp really isn't supposed to be bridged at 2ohms. I find that most are only 4ohm stable in bridged mode.
  3. Dec 3, 2009 at 2:06 PM
    Evil Monkey
    Robert
    Escondido, CA
  4. Dec 3, 2009 at 2:10 PM
    ItalynStylion
    Steven
    DFW, Tx.
    ^Yep, minimum impedance bridged is 4 ohms.
    You buy a sub that wires to 4ohms. Either that or try what you have at 8ohms. It wont have as much power but your amp wont blow up; and that's a plus.
  5. Dec 3, 2009 at 2:11 PM
    Evil Monkey
    Robert
    Escondido, CA
    Okay, thanks.
  6. Dec 3, 2009 at 2:20 PM
    ItalynStylion
    Steven
    DFW, Tx.
    No problem man. If you need any other help with it lemme know.
