Running E70 Gas in 2005 Tacomo V6 Five Speed Automatic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dogtrainer22, Dec 26, 2012.
  1. Dec 26, 2012 at 6:05 PM
    dogtrainer22
    dogtrainer22 [OP] New Member
    I am getting less gas mileage but significantly more horsepower. I like the way it accelerates with E70 in the tank.
    Other benefits include a cooler and cleaner running engine. This means the engine should last much longer than if I ran it with regular gas.
  2. Dec 26, 2012 at 6:10 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    I thought the more ethanol the more corrosive...
  3. Dec 26, 2012 at 6:13 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    I can't speak about the 2005, but there must be some reason that Toyota doesn't want me to run more Ethanol than E10 in my 2012.
    BTW, my 2011 F150 5 liter loved the Ethanol. Lots more HP but less MPG. It was designed for it too though.
  4. Dec 26, 2012 at 6:14 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Its pretty harsh on a lot of o rings and seals, even if they were built for it. Ethanol also absorbs water instead of displacing it. This means that even just sitting in your tank the fuel is absorbing water out of the air. I like 100% gasoline with some good detergents.
    But whatever floats your boat man. More power, More fun!
  5. Dec 26, 2012 at 6:17 PM
    EDJY
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Also this tacomo you speak of sounds pretty cool. haha. Maybe a mod will fix that for you.
  6. Dec 26, 2012 at 6:30 PM
    dogtrainer22
    It might be that the TRD Off Road package has a stronger built engine?
    200 proof ethanol will absorb water from the atmosphere and become 195 proof ethanol. The refineries produce 200 proof ethanol and then (before the water is absorbed) blend with 15 percent regular gasoline. Once ethanol and regular gas are blended, any water that enters the mix will not separate out into an individual layer; the gas station ethanol blend stays homogeneous in your tank while waiting to be burned by the engine.
    Be careful if you decide to switch to E45 - E70 by first transitioning to more ethanol gradually to allow the fuel system of your vehicle to slowly clean itself; too quick a transition will result in a clogged fuel system.
  7. Dec 26, 2012 at 6:32 PM
    Doc35
    Doc35 Well-Known Member
    Doc
    Virginia
    2012 DC MGM TRD Sport Prerunner
    Good luck.
  8. Dec 26, 2012 at 6:42 PM
    tvbd56
    tvbd56 Epic Member
    Tyler
    Sacramento, Ca
    2018 Black DCLB OR 4x4
    All 2005+ V6 engines are the same, there's no difference between the sr5/sport/off road
  9. Dec 26, 2012 at 6:58 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I don't care for ethanol, I will use it in my truck when I can't get regular gas, but I always try to run real petrol in my engine. Before the Tacoma when my 78 Ford Bronco was my daily drive, I filled it up with a tank of ethanol mixed gas because the station I normally got gas at for it was out. Long story short, I had water squirting out of both exhaust pipes and the engine was running like shit. I was so pissed I didn't keep the receipt for that and get my money back, needless to say, the people at Town Pump heard all about it. Probably shortened the life of my engine I bet.
  10. Dec 26, 2012 at 7:02 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I wonder when that engine is going to have issues
    :popcorn:
  11. Dec 26, 2012 at 7:11 PM
    dogtrainer22
    I started using E45 when I had 170,000 miles about eight months ago. Then I learned (by experience) that it would handle E70 without triggering a check engine light. For the last three months I have been burning E70 and I now have 195,000 miles.
  12. Dec 26, 2012 at 7:54 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    It is not a flex fuel engine so it should not be running ethanol. Not much else to say about that.
    Engine seal kit in your future.
  13. Dec 26, 2012 at 8:01 PM
    toon714
    toon714 Well-Known Member
    toon
    So. Cali to H-town
    2010 turbo lowered prerunner
    garret Gt 35R front mount turbo, TR lowering kit, Work wheels, all the go fast goodies!
    I hope u have a tune to run that ethanol.
    The stock ecu can not run that.
    I hope u have x1, or a stand alone running that ethanol.
    My proefi ems is equiped to.run e85. But dont have my flexfuel sensor installed to.run e85.
    Once I run e85 with my turbo ill gain a good amount of power vs pump gas.
    And theres is no gain for u if u dont have a tune to run it and can harm ur motor.
    Ur just wasting money and mpg vs pump gas.
  14. Dec 26, 2012 at 8:26 PM
    feyded
    feyded Member
    Whidbey Isle, WA
    2012 Toyota Tacoma TRD OR
    Good luck with your choice of craptastic fuel, there's a reason almost every manufacturer voids warranties from damage caused by the crap, as well as AAA recommending that you avoid it.
  15. Dec 26, 2012 at 8:26 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    No. It doesn't mean that at all. Post back when it all starts to fall apart and leak due to the E70 gas.
  16. Dec 26, 2012 at 8:30 PM
    toon714
    toon
    So. Cali to H-town
    Ur asking for a recipe to blow up ur motor.
    Just stay away from e85 unless u have a tune to run it.
  17. Dec 26, 2012 at 8:30 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    WTF OP
  18. Dec 26, 2012 at 8:36 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
  19. Dec 26, 2012 at 8:46 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
  20. Dec 26, 2012 at 8:47 PM
    dogtrainer22
    Now you have inside information. Let us see what you decide to do with it.
    I will report back once I am burning E100 in the Tacoma; I know--you think it is only possible to buy E85
