Running hot except when the heater is on...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Brandoni, Jun 24, 2015.
  1. Jun 24, 2015 at 6:22 PM
    Brandoni
    Brandoni [OP] New Member
    Brandon
    1999 Tacoma Sr5 4X4 V6 3.4
    Just got my Tacoma back ('99 Sr5 4x4 3.4 V6) after a rebuild. All new water pumps, thermostat, etc... It is running hot except when the heat is on. I replaced the thermostat again (from toyota) and the same thing is happening. The directions said that the jiggle valve should be within 15 degrees of vertical (which it is). Should I put the jiggle valve at the bottom? I read another post on here where that fixed the problem.
  2. Jun 24, 2015 at 6:25 PM
    TACO626
    TACO626 Well-Known Member
    Montclair, CA
    02 Tacoma 2.7
    Perhaps there's air in the cooling system.
  3. Jun 24, 2015 at 6:30 PM
    akuma1975
    akuma1975 Well-Known Member
    1997 tacoma
    Once is cool down . Open the cap and turn on the truck and look to see if the water is moving . I had the same problem and I put mine on the wrong way.
  4. Jun 24, 2015 at 6:35 PM
    oldracer
    oldracer Well-Known Member
    This may Not be Your problem; but I did see this situation on an older, 4 cyl car, a few years ago.
    As it turns out the radiator was, partially clogged from the owner using stop leak (don't know the kind of stop leak) to try to fix a leak where a stone made a small hole.
    The car never ran hot until a few bottles of the stop leak.
    He could turn the heater control on to full heat, and the car ran fine. Keep in mind the heater core is probably as big as the radiator on that car. It was a plastic/aluminum radiator. WE got another radiator from a salvage yard; and it fix the heating up problem.
    oldracer
  5. Jun 24, 2015 at 6:59 PM
    akuma1975
    1997 tacoma
    He is right feel the temp on the hose all 4 of them and see if they are the same temp
  6. Jun 24, 2015 at 7:09 PM
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    Id say its probably the radiator. If it was disturbed by the rebuild with high milage it is probably bad now
