Running Hot
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jonah.sloven, Nov 10, 2020.
  1. Nov 12, 2020 at 10:13 AM
    #41
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Agreed. It's like Airbus ECAM - there are millions of sensors on that machine, but they are not showed to the pilot unless there is a problem. In Tacoma the approach is more like Boeing Master Caution light: Engine Check light is like: something is f**ed up, better stop and figure it out. It is much better than constantly displaying tens of parameters that are within normal range.
    jbrandt[QUOTED] likes this.
  2. Nov 12, 2020 at 10:18 AM
    #42
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Check your radiator fluid level (when cold). I've seen the overflow reservoir look normal, but the radiator not have adequate fluid.
  3. Nov 13, 2020 at 8:23 PM
    #43
    eon_blue
    Azusa, CA
    Came back to ask if he ever got his scanner hooked up to see what the temperature was and it turns out the OP got banned :confused:
    I noticed he made a for sale thread for his truck yesterday, it got deleted though. Probably what got him the ban since he has under 50 posts.
    Curious why he decided to sell it all of the sudden
    TWJLee and Digiratus like this.
  4. Nov 20, 2020 at 12:08 PM
    #44
    Jonah.sloven
    Jonah.sloven [OP] Active Member
    Hey Eon,
    Ya got banned for posting for sale without the 50 posts. It was my buddies truck I thought I would see if anyone on here was in the market sold now, and lesson learned.
    So I got it plugged in and first test came back at 172 degrees and that was after driving for a while! then next time I plugged it in it was at 186. That number seems right on the money. Ill keep an eye on it and get some more tests but doesn't tell me much. No codes either I guess is always a good thing..
    Good to be back. sorry if I broke the ruled and offended anyone
    eon_blue[QUOTED] likes this.
  5. Nov 20, 2020 at 12:12 PM
    #45
    eon_blue
    Azusa, CA
    No worries, the mods are just strict with that rule because a lot of members on here have gotten burned/scammed by people in the past that joined solely to try and pocket people's money. It's nothing personal it's just a precaution they have to take to try and dissuade that from happening
    Good to hear your temp is in the normal range, 172 is pretty low...if it stays there often I would be wondering if your thermostat is stuck or something. But 186 is right on the money, that's a good operating temp to have. If your dash gauge needle is over the middle mark but your temp reading is 186, it's safe to say your dash gauge needle is just a little off. But that isn't something to worry about imo
    RysiuM likes this.
  6. Nov 20, 2020 at 12:52 PM
    #46
    RysiuM
    Rysiu
    I second that. The range for testing the sender is quite wide, and sensors change with the age. So the only think that that high needle is hurting is the OCD of the driver. It did it to me to the point that I was very annoyed and replaced the sender, even I knew everything is all right.
  7. Nov 20, 2020 at 12:58 PM
    #47
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    Not sure if anybody mentioned this, check your transmission fluid. My 2000 4runner overheated, radiator empty, tranny fluid pink. AKA Pink Milkshake.
