Running lean after Supercharger install
Discussion in 'Performance and Tuning' started by misteroldschool, Jan 1, 2018.
  1. Jan 1, 2018 at 4:15 PM
    misteroldschool
    misteroldschool [OP] Well-Known Member
    98 4x4 2.7l
    1998 taco, I bought this kit:
    http://www.lceperformance.com/3RZ-2-7L-Low-Boost-Supercharger-Kit-Smog-Legal-199-p/7015195.htm
    Its been on the truck since April, less than 10k miles on it so far. Since its the low boost kit they said that the computer would just figure everything out within ~500 miles. I had the truck on a dyno this summer and the AFR that they got was 16 (also only made 130hp) A few weeks ago I finally got a wide band sensor and daily driving it sits at 14.5 average. Iv been looking for boost reference fuel pressure regulators but cant seem to find one for a 3rz :( I dont know if thats the best route to go either.
    Anyone run into these problems? help?
  2. Jan 2, 2018 at 6:52 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sounds to me that you need to upgrade your fuel pump. As well as change your fuel filter. If those have not been done.
  3. Jan 2, 2018 at 8:30 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    14.7 is stoich and it's what you should see in closed loop when you're not in boost (idle, cruising) Does the 2.7 have a FPR that can reference a boost source like the 5vz? I'd definitely start with fuel filter like @Torspd said. Low boost shouldn't really need any major fuel mods if you're engine/fuel system is in good order
    Brice likes this.
  4. Jan 2, 2018 at 3:42 PM
    misteroldschool
    98 4x4 2.7l
    Filter was done maybe 3k before supercharger.
    Even then its boosting its at 14-15, Im trying to find a FPR that can reference boost cause the stock one cant, so far no luck.
    One more thing I forgot to mention is when it hits boost it feels like the timing retards cause it just falls flat on its face.
  5. Jan 2, 2018 at 8:26 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Knock sensor is probably pulling timing.
    Did you upgrade your fuel pump?
    vasinvictor likes this.
  6. Jan 13, 2018 at 10:59 AM
    misteroldschool
    98 4x4 2.7l
    I havent but im thinking its not the fuel pump because at 5k rpm suddenly it realizes its too lean and jumps to 13.
  7. Jan 13, 2018 at 7:22 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    As in "jumps" down, to 13? That is still too lean for boost. You should be in the 11's, in boost.
    cdelgado14 and inwood customs like this.
  8. Jan 14, 2018 at 4:52 PM
    misteroldschool
    98 4x4 2.7l
    ya it just suddenly jumps down
  9. Jan 14, 2018 at 5:38 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Seems more like a stagger as its still very lean lol
  10. Jul 15, 2018 at 9:44 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I’ve been running your setup for over a year, no issues. The stock FPR can absolutely be run to a boost reference port, mine is, there’s a port in the charger to do so.
  11. Jul 18, 2018 at 5:03 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    There was a urd fuel kit up for grabs in the for sale forum, maybe it's still available.
  12. Sep 13, 2021 at 4:48 PM
    James1996
    James1996 New Member
    James
    2004 Tacoma 2.7
    Low boost supercharger cold air intake
    So did you ever figure out the problem I am having the same exact problem?
  13. Sep 14, 2021 at 11:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have you upgraded your fuel pump, and replaced your fuel filter already?
  14. Sep 14, 2021 at 12:19 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    @BartMaster1234 has the 4cyl supercharger and has done some fueling mods, might have some suggestions
    With the 3.4l it's pretty common to need to either do the 7th injector fueling kit, or the larger 6 injectors, or methanol injection. Or go all out with a standalone ECU like the Haltech unit
    BartMaster1234 likes this.
  15. Sep 14, 2021 at 12:21 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You can run the 2001-2004 pink injectors for the 2rz/3rz that boast slightly higher CC ratings. However this is a bandaid, it'll never run at its full potential until you get a piggyback or standalone computer to fix the timing and fuel delivery.
    I run Methanol Injection and it does help it stay and maintain boost more effectively, however.
  16. Sep 14, 2021 at 12:23 PM
    eon_blue
    Azusa, CA
    Are you auto or manual trans?
    I've found the best way to keep closed loop pinging from happening is to shift at above 3K RPM so you aren't boosting below ~2500 RPM in the next gear.
    High gear/low RPM boosting is a great way to induce ping
  17. Sep 21, 2021 at 10:00 PM
    James1996
    James
    2004 Tacoma 2.7
    Well I'm guessing my fuel filter and pump is good because the afr gauge will go into the 12s after about 4500
    rpm but other than that it just stays in the 14s
  18. Sep 22, 2021 at 5:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sounds like the ECU has a late switch over to open loop.
