Running Lean with SC
Discussion in 'Performance and Tuning' started by WHT.RUS, Dec 8, 2014.
  1. Dec 8, 2014 at 8:15 PM
    WHT.RUS
    WHT.RUS [OP] Well-Known Member
    Will I know if my truck is running lean without a AFR gauge? Like getting error codes? Wondering if i can screw up my engine even though i did a reflash.
  2. Dec 9, 2014 at 6:55 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    If you're talking the TRD s/c and the factory ECU flash for said s/c & no other mods you will NOT run lean. It's going to run very rich but a wideband O2 would be a wise investment to be able to know exactly what's going on with your a/f ratio and will help greatly with future modifications.
  3. Dec 9, 2014 at 12:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If it starts pinging, or knocking, you'll know really quickly.
