Running light out NEED help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Goldtaco99, Jun 9, 2016.
  1. Jun 9, 2016 at 9:19 PM
    Goldtaco99
    Goldtaco99 [OP] Member
    99 Gold TRD Tacoma
    3 inch toytec spacers 33 12.50s on steel wheels
    I have a 99 xtra cab Tacoma TRD and my inspection is due this month. Noticed I had had 2 running lights out in the last couple weeks so I picked up bulbs for each.
    Replaced the front driver side which was burnt out and when I checked the back passenger side it was not burnt out.
    Replaced the bulb anyway and it still did not work. Check the wires near the tail light assembly to no avail.
    Doesn't anyone have any ideas on what it could be? Truck has about 120k miles
    Electrical is not my thing by the way.
  2. Jun 10, 2016 at 12:52 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Socket might be corroded .
    Correct bulb or defective ?? I know I tried using the wrong one at times not paying attention
    Trailer converter box ?? They love to cause problems.
    Broken wire someplace in the harness
  3. Jun 10, 2016 at 4:22 AM
    Goldtaco99
    99 Gold TRD Tacoma
    Everything looks to be pretty clean and the bulb looks the same but like I said the old one was not burnt out.
    Last time I had an issue with the trailer light harness( I think that's what you meant by converter box) on a different truck it blew the fuses and I had no lights whatsoever.
    It doesn't seem likely to me that I wire broke inside the harness but like I said I'm not an electrician.
  4. Jun 10, 2016 at 4:27 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    You check all of your fuses? Any other lights of the assembly working? Check the outlet with a volt meter.
  5. Jun 10, 2016 at 4:33 AM
    Goldtaco99
    99 Gold TRD Tacoma
    Every other light on the truck works except the rear passenger side running running light.
    How many volts should it have running to it?
  6. Jun 10, 2016 at 4:33 AM
    TacoTRD78
    Stuart,fl
    That im not sure of probably 12 i would assume
  7. Jun 10, 2016 at 4:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    12
  8. Jun 10, 2016 at 4:38 AM
    Goldtaco99
    99 Gold TRD Tacoma
    I'll try that later on today hopefully. Thanks
  9. Jun 10, 2016 at 5:12 AM
    TacoTRD78
    Stuart,fl
    Try the the plug adapter also that the headlight assembly plugs into.
  10. Jun 10, 2016 at 5:55 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    A lot of the passenger tail light is fed from the driver side light. The wires are routed underneath the bed below the tailgate. You could easily have something damaged here. I still suspect the trailer harness though. I've replaced mine twice and there are still lingering issues, mostly due to moisture in the trailer plug. I have LEDs though, so they are more sensitive to electrical voltage changes.
  11. Jun 10, 2016 at 5:57 AM
    TacoTRD78
    Stuart,fl
    Your probably right I dont have a first gen. i was just trying to help by stating some things that it could be.
  12. Jun 11, 2016 at 1:06 PM
    gmr102
    gmr102 Well-Known Member
    Utah County
    Formerly: 2002 Silver Stepside TRD OR Ext Cab V6 Current: 2008 Lexus GX470
    I had the exact same issue. What fixed it for me was connecting the drivers side running light to the broken passengers side light. I believe that on the first gens the two running lights have 2 separate wires running from the fuse box. With them connected to each other they work fine now. The only issue I have is keeping the socket on the truck nice and clean.
  13. Jun 20, 2016 at 7:30 AM
    madbashcar
    madbashcar Member
    2003 Silver Double Cab Pre Runner
    Having similar issues with passenger side lighting, but only if I hook up a trailer with the light harness. Voltage reading from the plug on the truck shows a five volt drop in voltage for brakes and turn signal on passenger side. Lights work fine with nothing connected to plug. Going to try and replace plug and see if that helps.
