Running lights and license plate lights are out
Discussion in '1st Gen. Tacomas (1995-2004)' started by page1111, Apr 18, 2018.
  1. Apr 18, 2018 at 5:09 PM
    page1111
    page1111 [OP] New Member
    I have a 2004 Toyota Tacoma and the rear running lights and license plate lights are out. the brake lights do work. I have looked at the fuses and wire connections (connections in the fuse block as well) and look ok. what could cause this problem?
  2. Apr 18, 2018 at 7:03 PM
    Glamisman
    Glamisman Well-Known Member
    check for voltage at the tail light fuse, if not there, the tail light relay which supplies power to the tail light relay could be bad. the tail light relay is controled by the body ecu.
  3. Apr 19, 2018 at 1:48 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you have a trailer light converter box another place that can cause problems
