Running lights not working
Discussion in 'Lighting' started by 02TACOMA4WD, Feb 9, 2012.
  1. Feb 9, 2012 at 3:27 PM
    02TACOMA4WD
    02TACOMA4WD [OP] Well-Known Member
    02 Tacoma TRD 4x4
    I have searched and searched and I have found nothing. So here's the deal, my " daytime" or "running" lights in the rear are not working. The weird thing is that my brake lights still work. I don't know if it is just a fuse or something like that.I just replaced the dual filament bulbs. Has anyone else had this problem? also my license plate lights are not working, also replaced those to.
  2. Feb 9, 2012 at 3:29 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    sounds like a blown fuse.. check them
  3. Feb 9, 2012 at 3:32 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    The fuses in the cab? Which fuses should it be?
  4. Feb 9, 2012 at 3:33 PM
    Blackshirts
    TX
    09 PreRunner
    Stuff
    there should be fuses in the cab and some under the hood. and on the back of the panel should be a diagram of what fues are where.
  5. Feb 9, 2012 at 3:49 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    Thanks man, I went and looked and there wasn't even a fuse in the slot! So I'm just gonna run down to auto zone and buy a box of fuses and I believe it should be good! Thanks for your help man!
  6. Mar 28, 2012 at 7:26 PM
    Fotno
    Fotno New Member
    Jared
    Houma
    06 2.7L
    Anyone Happen to know which fuse is it? I cant seem to find it.
