Running no cats?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SRQ TACO, Jul 12, 2011.
  1. Jul 12, 2011 at 9:22 PM
    SRQ TACO
    SRQ TACO [OP] Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    Ok I tried to rear that other thread but it was a disaster. Ok here's my situation.
    I have my 2000 2rz. It was from California meaning it has 2 cats. My problem is the cats have gone bad and I'm throwing a P0420 code. It wouldn't be a huge problem but a red CEL on a blue gauge cluster looks horrid and the truck is now getting a pathetic 16mpg city. I do not want to buy 2 new cats so I was wondering if I remove cat #2, gut the 1st cat, run a URD O2 simulator, and weld in a Dynomax Super Turbo muffler will the truck run good and will it be more efficient?
  2. Jul 12, 2011 at 9:27 PM
    SRQ TACO
    Damon
    Sarasota, Florida
    Stinks like dirty cat and Ive replaced everything associated with that code already but the cats themselves.
  3. Jul 12, 2011 at 9:30 PM
    SRQ TACO
    Damon
    Sarasota, Florida
    Will I gain gas mileage again?
  4. Jul 12, 2011 at 9:46 PM
    SRQ TACO
    Damon
    Sarasota, Florida
    Well I know for a fact a 2rz should be getting 20mpg easily in the city. So what else should I look for to be sucking gas mileage?
  5. Jul 12, 2011 at 11:02 PM
    SRQ TACO
    Damon
    Sarasota, Florida
    Filter as in which one?
  6. Jul 12, 2011 at 11:04 PM
    SRQ TACO
    Damon
    Sarasota, Florida
    And to throw this off topic because it will happen.
  7. Jul 12, 2011 at 11:44 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    o2 sensors will cause your truck to run rich, meaning it wont know how much fuel it is using. So it might try sending too much fuel when it really needs less.
  8. Jul 13, 2011 at 3:59 AM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    Did you use Denso replacement sensors? I dont know the answer to your question, but your idea seems quite logical. Sucks having 2 cats!
  9. Jul 13, 2011 at 7:44 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    I'm scheming of a similar plan. from my research using the search feature, the poor mpg's is attributed to a bad bank 1 sensor (the 'front') make sure you get the OEM Toyota (denso) replacement, don't buy a Bosch or any universal, word on the street is they're problematic. Do it right the first time.
    I've got my new bank 1 waiting in my garage, but am waiting for my new front high-flow cat and URD sim to arrive before i get to work on it. Still can't decide if i'm going to put another high flow secondary cat in or just weld in a length of tube... I'll most likely just shell out for a secondary so i don't lose the low end too much. but idk... gdlk, if you do ditch 'em, let us all know how it turns out.
  10. Jul 13, 2011 at 11:07 AM
    SRQ TACO
    Damon
    Sarasota, Florida
    Whoa guys calm down I said I replaced both the O2 sensors already.
