Running no front axles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chachie, Oct 17, 2011.
  1. Oct 17, 2011 at 11:28 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    :devil: Poking the fire is see!!!:poking:
  2. Oct 17, 2011 at 11:31 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You can say that CV Axle compresses inner and outer bearing , thus holding wheel bearing together. ;)
  3. Oct 17, 2011 at 11:33 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    It appeared everybody else had the technical side covered. :D
    Fink
  4. Oct 17, 2011 at 11:34 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Oh, I am confused. I am not saying you are wrong, only trying to understand. I thought the wheel bearings were a pressed in, sealed unit.
  5. Oct 17, 2011 at 11:34 AM
    Toyota Tech31
    Debary, Florida
    I hear ya, i got a kick out of it.
  6. Oct 17, 2011 at 11:41 AM
    BlueT
    NorthEast
    They are pressed in and sealed. You press them over the wheel hub, but thats not permanent. What CV does it simply holds everything together.
  7. Oct 17, 2011 at 11:43 AM
    Leggo
    Newton,Ma.
    ok thanx
  8. Oct 17, 2011 at 11:56 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    It is 100% correct that the splined stub of the outer CV joint and the axle nut are what hold the wheel bearing together. These wheel hubs are different then the older toyota IFS hubs, are now basically just a bigger version of a FWD car hub. The only way to do this would be to remove the joints from shafts and put the joints back in with no shafts, which would be silly, for the amount of work involved. It would make much more sense to do it once, and do it right.
  9. Oct 17, 2011 at 12:08 PM
    Chachie
    Chachie [OP] Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    Ok I've got bigger problems... Under acceleration in 2wd, my truck feels like an out of balance washing machine...
  10. Oct 17, 2011 at 12:24 PM
    MsTRD
    MsTRD hell yes i love my truck
    Samantha
    Rohnert Park, CA
    06 White Prerunner TRD Sport
    what did you do to my truck?!
  11. Oct 17, 2011 at 12:35 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Install a BeefedTaco carrier bearing drop bracket.
  12. Oct 17, 2011 at 2:22 PM
    Chachie
    Justin
    Nor Cal
    I've already got a 1" carrier bearing drop.
  13. Oct 17, 2011 at 2:32 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
  14. Oct 17, 2011 at 3:12 PM
    toytaco970
    toytaco970 Well-Known Member
    avon/vail, co
    05 trd offroad 4x4
    Front: Icon IVD coated extended travel coilovers Rear: 5125's with AAL and 1" block. Front sway bar removed. Brute Force Fab bumpers AllPro stuff: UCAs , front skid plate, sliders, rear u-bolt flip kit, e-locker guard Kenwood/Garmin single DIN DVD-NAV system, amp and sub. V1 radar, Foglight anytime mod,
    1. Kinda hard to replace the axles, break components, new wheel bearings, and install a lift kit by myself if I don't understand the front end of my truck. :cool:
    2. Go ahead and take your axles out and see how far you get. ;)
    MJP2: "They disassembled the CVs and installed them in both the differential end and the wheel end with nothing in between."
    Now thats a good idea, I never even thought of that when I f-ed mine up, the wheel side still has the axle nut/shaft on holding the damn wheel on the truck with more than the wheel bearing.
    3. EMPI has a good rep in the fwd world. I definitely would have got OEM axles until I saw the price. Plus now I can rebuild my OEM axles, having them as a backup and take my time with it because its a messy PITA job.
    Thanks to everyone else for their comments who has actually turned a wrench or two in their lifetime. :cheers:
    __________________
  15. Oct 17, 2011 at 3:25 PM
    #35
    jandrews
    '09 FourDubDee TRD OR
    you don't get to post anymore, k?
    :cheers:
  16. Oct 17, 2011 at 3:32 PM
    #36
    toytaco970
    avon/vail, co
    05 trd offroad 4x4
    Just noticed in your profile that you have a 6" lift,
    How long have you had that 6" fabtech kit on?
    I'd go thru the whole thing and check and re-torque everything
  17. Oct 17, 2011 at 3:35 PM
    #37
    jandrews
    Fixed that for you :)
  18. Oct 17, 2011 at 5:46 PM
    #38
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Almost 2 years for him...[​IMG]
  19. Oct 17, 2011 at 6:04 PM
    #39
    jandrews
    Except that they are in. The spuds, anyway, which essentially act like a bolt holding your wheel bearing assembly, wheel, and tire to the spindle. Kind of important.
  20. Oct 17, 2011 at 8:54 PM
    #40
    Chachie
    Justin
    Nor Cal
    Quite honestly, if someone has a crossmember I can weld in, I'll be LT in a month or so. I'm so sick of the DB lift.
