Running no front axles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chachie, Oct 17, 2011.
  1. Oct 18, 2011 at 3:24 AM
    #41
    Chachie
    Chachie [OP] Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    Well guess I figured out what the vibration was.....
  2. Oct 18, 2011 at 4:09 AM
    #42
    jandrews
    '09 FourDubDee TRD OR
    Have one made. It's not terribly expensive.
  3. Oct 18, 2011 at 6:38 AM
    #43
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Damn...
  4. Oct 18, 2011 at 6:57 AM
    #44
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Without being able to look under my truck I can not make out what it is. Looks like fluid, am I right?
  5. Oct 18, 2011 at 7:19 AM
    #45
    98tacoma27
    Ben
    Not Beech Creek
    Oh, ouch. What do you bust off? It almost looks like the TC actuator but that's on the back of the TC I believe.
  6. Oct 18, 2011 at 7:20 AM
    #46
    mjp2
    NJ
    You've got some work to do to figure out exactly what happened. The fluid is one thing, but the u-joint dangling there without end caps is more concerning.
    Did you disassemble things or did you find it this way? Definitely get some better photos in the daylight.
  7. Oct 18, 2011 at 7:25 AM
    #47
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    ohh dam!!
    that sucks man. interested in the outcome
  8. Oct 18, 2011 at 7:55 AM
    #48
    Chachie
    Justin
    Nor Cal
    That I's the u joint at the tcase. Broke the actuator off the back of the tcase, luckily not the tcase itself.
  9. Oct 18, 2011 at 7:59 AM
    #49
    98tacoma27
    Ben
    Not Beech Creek
    So you broke the rear DS u-joint?
  10. Oct 18, 2011 at 8:01 AM
    #50
    Chachie
    Justin
    Nor Cal
    And the yoke...
  11. Oct 18, 2011 at 8:07 AM
    #51
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    It looks like that U-joint did not see a grease gun for long time ;)
  12. Oct 18, 2011 at 8:07 AM
    #52
    98tacoma27
    Ben
    Not Beech Creek
    You're not the first to do that. I blame the non-greasable u-joints. How long have you been driving in 4wd?
  13. Oct 18, 2011 at 8:10 AM
    #53
    BlueT
    NorthEast
    His truck says 4wd so he has zerks to grease them. Looking at dry rusted u-joint I am guessing those Ujoints never got any grease.
    So now what is 5 minute job costing few pennies had turned into big job that will cost him $$$. Grease your U-joint folks :)
  14. Oct 18, 2011 at 8:12 AM
    #54
    98tacoma27
    Ben
    Not Beech Creek
    I can never remember which one has the non-greaseable joints.
  15. Oct 18, 2011 at 9:42 AM
    #55
    Chachie
    Justin
    Nor Cal
    Yep it's grease-able. Completely my fault. Here's new pics. The yoke is fine thankfully. Just the intermediate shaft and the tcase actuator.
  16. Oct 18, 2011 at 6:10 PM
    #56
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    Yep,don't think has been greased very often. I though only 4X4s had fittings but my manual say the prerunner with the 2.7 has fittings also.Thats kinda weird.
  17. Oct 19, 2011 at 11:52 AM
    #57
    Chachie
    Justin
    Nor Cal
    Well the stealership wants $840 for the actuator. I am picking up the other parts today for about $125.
  18. Oct 19, 2011 at 2:11 PM
    #58
    jandrews
    I'd try and source one from a junkyard truck.
  19. Oct 19, 2011 at 3:05 PM
    #59
    Chachie
    Justin
    Nor Cal
    The problem with that is no salvage yards want to separate the actuator from the tcase.
  20. Oct 19, 2011 at 5:47 PM
    #60
    jandrews
    Can probably find an actuator + t-case for price of new actuator from dealership. Might as well have a spare for the same money, no?
