Running of out gas test
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wjb, Jul 20, 2017.
  1. Jul 20, 2017 at 3:41 PM
    wjb
    wjb [OP] Member
    Bill
    Morrison, Co
    '16 TRD SPORT 4X4 DBL CAB 5' BED V6 6-Spd MT Quicksand
    I'd like to test:
    - How far my 2016 Taco will go after the low gas light comes on.
    - How low the fuel gauge goes when the tank is really empty.
    - How accurate is the Miles to Empty digital dash display.
    I'll carry a gas can with 2.5 gal and run it to empty.
    Is there any concerns with getting it restarted after running it to empty?
    Anything to prime like a fuel pump, filter, etc.?
    Is 2.5 gals enough to get restarted?
    I know it's not a good thing to do on a regular basis and
    can suck stuff off the bottom of the tank but
    doing it once to really know what happens on a
    Taco with only ~12k mi and 1 1/14 years old can't be too bad.
    Anyone else do this on a newer Taco?
    I couldn't find any posting about it.
    ChadsPride likes this.
  2. Jul 20, 2017 at 3:43 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    It'll start fine. People run out of gas and get them restarted every day, just push the start button or turn the key once she's got some more gas in it.
    Some will probably tell you you're going to soak up a bunch of sediment from the bottom of your fuel tank that will get into your fuel injection system which is basically just hogwash.
    Give it a whirl, let's see what the results are.
    wilcam47, PROseur, ChadsPride and 3 others like this.
  3. Jul 20, 2017 at 3:44 PM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    A safer test would to be: read the manual and see when the light comes on.
    Another safer test: look up the tank capacity, when the light comes on, fill it up. Calculate the difference you could also run it to 0 then fill it and calculate the difference.
    Running it dry is asking for problems for no reason.make sure the fuel pump is primed if you do decide to do it. Otherwise it should start.
    I don't know that I trust this particular engine to.
    Edit: for the record I got it to "--" aka 0 and it had about 2 gallons left iirc.
    Oregon TRD Off~Road and wilcam47 like this.
  4. Jul 20, 2017 at 3:50 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I'll save you some time.
    The fuel gauge will bury into the E when you're super empty.
    You still have fuel left in your tank even when the miles to empty is at 0.
    The miles to empty is not that accurate as per above. It is calibrated on the side of safety to get you to a gas station.
    dYL0n likes this.
  5. Jul 20, 2017 at 3:50 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    the light turns on when you have 3 gallons left in the tank.
    Ask me how I know... 55k miles.
  6. Jul 20, 2017 at 3:50 PM
    psvines
    psvines Well-Known Member
    2016 SR5
    I've calculated about 25-30 miles left when at zero. I've never let it get below 40 miles remaining.
  7. Jul 20, 2017 at 4:00 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  8. Jul 20, 2017 at 4:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    You will know some specifics for your truck. Assuming the next time you get in that situation that you drive it exactly as you do this time.
    How far you will go and how far it says you have left are filled with variables for each event. Speed, terrain, weather, etc etc, just like any fuel burn rate.
    You'll have a good guess, but thats all. And the light on how much is left may, or may not apply to other trucks. Gauges can vary a bit.
    It's actually easier to hit a station right when the light comes on, top it off on automatic shutoff. Subtract what you put in from tank capacity to know pretty close to what was left. Then apply your log book MPGs for your current driving conditions to know how far you could have gone.
    You do already log each tank, do the math and note the conditions it was used under, right? :)
  9. Jul 20, 2017 at 6:45 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Your Truck is fairly new so I wouldn't worry about sediment.
    Just watch out where you run out of gas.
  10. Jul 20, 2017 at 6:47 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Im surprised nobody mentioned the 1 and only thing that keeps the fuel pump cool is........
    shady 74, Toyko Joe, PhogDog and 3 others like this.
  11. Jul 20, 2017 at 6:49 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Tank is 21.9 gallons I think? Or 21.1? Anyhow, I let mine go to "--" miles remaining and i only put like 18 gallons in.
  12. Jul 20, 2017 at 9:33 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    I ran my 16' T4R down to 1 MTE coming back from Chico. I only put 21 gallons in it. Capacity is 23 gallons.
    goofydug and ChadsPride like this.
  13. Jul 20, 2017 at 9:59 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    I code-browned the hell out of a tank of gas once.
    Capacity: 21.1 gallons.
    Mine isn't fancy enough trim level for a "distance to empty" readout though. I was definitely on E and the light was on, but it wasn't flashing at me or sputtering or anything.
  14. Jul 20, 2017 at 10:35 PM
    Donkeythekidd
    Donkeythekidd Well-Known Member
    Beaumont, CA
    2017 MGM Tacoma TRD Off Road Double Cab
  15. Jul 20, 2017 at 10:41 PM
    smitty99
    Scottsdale
    After it says zero miles remaining there are still about 2 gallons left of reserve which is another 30 to 40 miles of range depending how you drive.
    The light comes on when there are still at least 4 gal. Remaining.
    ChadsPride and Beerpayzdabillz like this.
  16. Jul 20, 2017 at 11:08 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Fuel light came on and said this distance was remaining, after a day of playing in dirt and a road trip.. drove over 400 miles that day, but filled up at this point before I reached home.IMG_0567.jpg
    The above photo was just before I shut off to fill up.
    We know the tank is bigger than 18.6...
    Sounds pretty much in line with what everyone else has said.
    SilverII likes this.
  17. Jul 21, 2017 at 4:26 AM
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    I have the same truck as you do. Does the needle go as far below the "E" line when empty as it goes above the "F" line when full?
    My truck gets 140miles on the first quarter and the amt above the F line. The other 1/4 tanks are exactly 100miles down to the E line. When I fill it ends up being 18 gallons and change. Based on my mileage I should get 140miles from the first and last 1/4 tanks of gas.
  18. Jul 21, 2017 at 4:45 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Damn OP, you'll be fine. People run out of gas all the time. Like you said, a single time in a newer vehicle won't do anything particularly bad.
    wilcam47 and PROseur like this.
  19. Jul 21, 2017 at 4:48 AM
    DrFunker
    DrFunker Well-Known Member
    Not sure if mentioned above but....not a great idea to run it down til empty. But your truck, your money.
  20. Jul 21, 2017 at 6:55 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I have a little over 1 gallon remaining when it says 0 miles to empty....tested this a couple times now.
