Running OR lights wire....
Discussion in 'Lighting' started by Taco Gunner, Aug 9, 2010.
  1. Aug 9, 2010 at 12:52 PM
    Taco Gunner
    Taco Gunner [OP] Well-Known Member
    Arizona
    2006 Access Cab TRD Offroad
    Avid bar..just curious what some of you guys have done to run the lights wiring from the bar to the cabin. Pics would be helpful. I want a very clean look...
    Thoughts?
    Two Hella Rallye 4000 lights......
  2. Aug 9, 2010 at 12:56 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Run wires along existing wire harness. Use wire loom to protect the wires. Use the grommet next to the steering shaft to access the cabin.
  3. Aug 10, 2010 at 10:12 AM
    Taco Gunner
    Arizona
    What about from the bar? I have considered drilling small holes on the bar and running the wire that way to the front of the truck. Again, looking for a clean run.
  4. Aug 10, 2010 at 10:16 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    Check out my DIY running lights in my signature for ideas. Also, you can check out my bed lights for pics of the grommet in the firewall...you should power them off the battery if they are lights and not LEDs.
  5. Aug 10, 2010 at 10:16 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    If you drill into the bar, that's the place it will rust first.
    Seal the holes with silicone caulk. That'll slow it down.
  6. Aug 11, 2010 at 7:11 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    my wires come off the lights and go into the opening in the bumper. I used small wire looms to cover the wires.
