Running out of options
Discussion in '1st Gen. Tacomas (1995-2004)' started by Redfisher16, Sep 18, 2017.
  1. Sep 18, 2017 at 3:05 PM
    Redfisher16
    Redfisher16 [OP] Member
    2004 Tacoma prerunner
    Alright, 2004 Tacoma 3.4l. Changed the valve cover gaskets and a day later I get a P0302 code. I've changed fuel injector, plugs, coil pack, plug wires, cleaned maf sensor as well as throttle body. I've noticed an electrical hum coming from the lower part of my throttle body. I don't know if it's always done that or if it just started it. Ideas on why it would do that? Did a compression test on all cylinders. All but 1 was at 180 +/- 5psi. I had one at 170 but it's not the cylinder that's missing. What's next I the list? Any help or advice will be greatly appreciated..
  2. Sep 18, 2017 at 3:28 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Did you clear the code and it came back?
  3. Sep 18, 2017 at 3:29 PM
    Redfisher16
    Yes, cleared it and disconnected the battery leads for a few minutes. Sitting at idle it's fine, a very hesitant stutter every now and then. But when it's under a load the whole truck rattles
  4. Sep 18, 2017 at 3:58 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    These were all new parts you swapped in??
    Since things got moved around look for loose connections
    Bent pins on plugs only takes one
    Redfisher16[OP] and Dalandser like this.
  5. Sep 18, 2017 at 4:00 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Usually if something like this happens you have damaged an injector plug, wire or something.
  6. Sep 20, 2017 at 11:30 AM
    Glamisman
    Glamisman Well-Known Member
    what upper and lower manifold gaskets did you use? did you reuse the gaskets? The factory metal ones in my opinion are the only ones to use. I have seen aftermarket fibre gaskets suck through and cause this problem.
    Redfisher16[OP] likes this.
  7. Sep 20, 2017 at 2:43 PM
    Redfisher16
    It was a new plug, injector and coil pack. And I even swapped packs around on the engine just to make sure
  8. Sep 20, 2017 at 2:44 PM
    Redfisher16
    Yes, checked them and they were still in good shape. I did check for a intake leak by spraying carb cleaner around it while it was running.
