Running rca and ground wires in access cab
Discussion in 'Audio & Video' started by Lizard1080, Mar 8, 2010.
  1. Mar 8, 2010 at 9:26 AM
    Lizard1080
    Lizard1080 [OP] Well-Known Member
    Chase
    Georgia
    07 5lug SR5
    Readylift SST 5 lug, T-Rex Eyelids, Alpine CDA-105, 12" Alpine Type-R, Kenwood 1000w amp
    I'm waiting for my wires and amp and sub box to get here and getting ready for the install. Running the power cable seems easy but where do i run my rca and ground cables in an access cab? Thanks.
  2. Mar 8, 2010 at 11:31 AM
    81shark
    81shark Well-Known Member
    depends on where your amp is.
    mine is under the drivers seat. i ran the rca wires down behind the dash, under the center console to the back of the center console and then out the lower side to the drivers seat.
    i've got a few zip ties under the console to hold the wires in place.
    i grounded to the driver seat bolt
  3. Mar 8, 2010 at 12:27 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    id say either under the console or pull up the door sills and run them thru there.
  4. Mar 8, 2010 at 2:17 PM
    81shark
    for what it's worth, i kept mine in the console to keep the RCA wires away from the power wire that i ran under the door sill. although i could have gone done the passenger sill. i was concerned with interference from the power wire, however, i did run speaker wire down the driver side door sill and havne't had any noise issues.
  5. Mar 10, 2010 at 2:27 PM
    JoeSchmuck
    JoeSchmuck Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    I like the console idea myself. It's good to read these forums, many good ideas and practical experience.
