Running rich and stumbling
Discussion in '1st Gen. Tacomas (1995-2004)' started by Allex95, Mar 8, 2023.
  1. May 5, 2023 at 12:11 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    When I had the old injectors in a year ago....
    .....at highway speeds I was getting like +30....
    and back to zero at idle....crazy
    but I also put a brandnew egr valve in there too...
    so too many changes to track what happened..
  2. May 5, 2023 at 12:12 AM
    Allex95
    Allex95 [OP] Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    Yea it fluctuates like sometimes it’s okay then sometimes it’s up way high. My main concern is smell of gas fumes and sometimes like stumbling
  3. May 5, 2023 at 12:13 AM
    O'Silver_Taco
    MD
  4. May 5, 2023 at 12:15 AM
    Allex95
    allex
  5. May 5, 2023 at 12:15 AM
    O'Silver_Taco
    MD
    Sure you dont have an O-ring around one of the injectors leaking....
    it would evaporate fairly quickly....so might be hard to catch....
  6. May 5, 2023 at 12:18 AM
    O'Silver_Taco
    MD
    Yeah thats reason I went and replaced everything on the truck....
    so I knew where everything stood......
    like the pinched hard line on the passenger caliper...
    or the rusty needles in mid universal joint.....
    So yeah after changing the egr and injectors....I went from +30 back down to more reasonable +7.
    But anything interfering with the air flow from the maf to that ass end O'2 sensor will cause trim swings...
    Other than pump and fuel regulator.....thats all you can do on that end....
  7. May 5, 2023 at 1:01 AM
    Allex95
    allex
    I replaced the first 02 sensor what about the second one? After the cat
  8. May 5, 2023 at 10:38 PM
    O'Silver_Taco
    MD
    I think its the first one thats important.....the 2nd one will only throw a code if the cat is failing/insufficient.....
    The 2nd on my truck probably came with the truck from factory.....couple/three years ago I got a code on first one....
    so I replaced them both......
    They were not cheap.....over $100 each....and that was about 3 or 4 years ago.......
    And even then....its the heating element that goes out on em.....
    they work fine for years after everything heats up........even when they thro the code...
    heating element has gone out....
