Running rich?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Drewski, Nov 3, 2011.
  1. Nov 3, 2011 at 4:55 PM
    Drewski
    Drewski [OP] Well-Known Member
    People's Republic of Chicago
    '99 Prerunner SR5 Xtracab 4 cyl auto
    Hey all, still unfamiliar with this 2.7L motor, and 'yotas in general, but a tune up is a tune up, right? I swapped the plugs, wires, and cleaned the MAF (didn't touch, sprayed with MAF cleaner only.) The last couple starts smelled pretty rich, so I just pulled the plugs and they're all sooty already. The plugs I swapped out were kinda grey. The new ones are definitely black - there's maybe 30 miles on 'em. I had the battery unplugged for a while, so I assume there was an ECU reset and it needs to relearn? Anyway, I regapped the plugs a bit wider than the .032 that Autozone recommended; I've read different gaps on the various online info for this motor.
    No CEL though; am I just paranoid? The truck seems to run smooth and idles nice and low now, like 600-700 rpms.
  2. Nov 3, 2011 at 6:10 PM
    killzone90
    killzone90 Well-Known Member
    Ethan
    Fairdale,ky
    96 tacoma
    What kind of plugs u running
  3. Nov 4, 2011 at 5:35 AM
    Drewski
    I put the new NGK wires and V-power plugs in at 0.032 and ran it for a few days, but I just regapped them to 0.042.
  4. Nov 4, 2011 at 7:20 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Check your temp sensors, air and coolant and O2 sensor, for proper operation. Also, after replacing a sensor or doing a tune-up, disconnect the battery for 15 min to reset the ECU. It will start with the factory parameters for the fuel mix.
    Marginal temp sensors will not set a code; they will just cause fuel and timing related problems. The ECU will think it's running in a cold or hot envioronment when it isn't.
  5. Nov 4, 2011 at 9:32 AM
    pigger
    pigger Well-Known Member
    Greg
    Applecookie
    04 tacoma 4x4 reg cab
    Detroit True-Track rear limited slip, steering rack bushings, shell, SAF decals, Wheelers 5-leaf & Bilstein 5100's, some nice LED lights from Chris, older-than-dirt owner
    My '04 runs pretty rich when first started (you can smell it), then leans out to normal. Has always done this.
  6. Nov 5, 2011 at 9:25 PM
    Drewski
    Have you checked your plugs lately? Mine are nicely blackened. 30 or so miles since installed. I regapped and drove another 25, so I'm curious to see if time helps. Just to be safe, I unplugged the battery while I was at work so the ECU should be all nice n reset.
    In a completely unrelated story, I made fast friends with a local gearhead - the real deal, old school, Stingrays and Goats and 'cudas (oh my!) etc. Chatted about the "old days" for a while, and it turns out he owns a body shop. I deftly steered the conversation to this "sweet '99 taco out of AZ with no rust and a sunburned paint job" and he told me to bring it in, he'd set me up. Two-stage, factory color, all emblems replaced, door dings removed for, drum roll.... $1500! I've seen his work, this place does not mess around. Only thing is, I owe him a ride in the old man's '57. :eek:
  7. Nov 6, 2011 at 7:40 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Nice deal!
