running rough and multiple warning lights on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DR2011, Nov 9, 2022.
  1. Nov 9, 2022 at 3:47 PM
    DR2011
    DR2011 [OP] Member
    2011 Tacoma TRD 400,000 miles
    ABS, parking brake, stability control, and check engine light on. Idle RPM about 750 without AC on, jumps a little higher with AC. Very rough running and acceleration.
    Any suggestions I can do in my garage?
    2011 TRD Off Road.
    My baby is running rough and only has 421,000 miles.
  2. Nov 9, 2022 at 4:27 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You are going to need to scan it for codes.
    The codes will give a direction on where to start diagnosing the problem:thumbsup:
    DR2011[OP] and Dm93 like this.
  3. Nov 9, 2022 at 5:27 PM
    DR2011
    DR2011 [OP] Member
    thank you for the confirmation. that's is the direction i was headed
