running rough but no code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jbmdux, Sep 3, 2019.
  1. Sep 5, 2019 at 10:03 AM
    badger
    badger Well-Known Member
    07 SR5
    jbmdux[OP] likes this.
  2. Sep 5, 2019 at 10:38 AM
    jbmdux
    jbmdux [OP] Member
    john
    2015 TRD Off Road
    Trifecta Tonneau Cover
    I thought so, so that means removing the bed would have to be removed to replace it? I sure hope I can avoid that.
    BassAckwards[QUOTED] likes this.
  3. Sep 5, 2019 at 10:39 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Bed removal is not reqd but the tank has to be dropped. You should be able to take loose all connections by lowering the tank a little, the disconnecting, and then lowering the restof the way.
    jbmdux[QUOTED][OP] and wilcam47 like this.
  4. Sep 5, 2019 at 10:46 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    My experience is when the MAF is that bad, it will throw a P0171 code/CEL, though. No codes here is perplexing, so I venture it's something mechanical.
  5. Sep 5, 2019 at 10:50 AM
    BassAckwards
    @05prerun82 do you remember having a CEL/trouble code when your MAF was dirty? I dont think i remember this happening, and it was pretty bad.
    Either way, it's a good starting point, could be a $5 fix for some MAF cleaner
  6. Sep 5, 2019 at 11:22 AM
    05prerun82
    05prerun82 Your local friendly Taco Mule TTC#0202
    Brandon
    Fredericksburg
    2006 aclb prerun
    Memphis sound system volant cold air intake
    No code just ran bad
    jbmdux[OP] and BassAckwards like this.
  7. Sep 5, 2019 at 11:52 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    2004 was the last year any Tacoma had a factory-provided external fuel filter. My '04 Tacoma had one under the hood - drivers side near engine block - inline 4 cyl. The one in the photo mounted alongside drivers door frame rail may have been from a previous yr. or that's how they were mounted on the V6.
    Boy...do I ever wish my 2015 V6 had an external fuel filter.
  8. Sep 5, 2019 at 11:55 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    My 2000 V6 was on the driver frame rail. Loosen the gas cap to depressurize, remove the two fuel line banjo bolts then remove the clamp bolt and it's about as quick and easy as that.
  9. Sep 5, 2019 at 12:48 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    No chance man the fuel filter in the fuel pump assembly on that year
  10. Sep 5, 2019 at 12:49 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    And if the Tacoma like the Corolla your gonna be paying close to 500 for fuel pump assembly
  11. Sep 5, 2019 at 12:58 PM
    05prerun82
    Brandon
    Fredericksburg
    2006 aclb prerun
    Mine did the same thing at around 95k but I changed spark plugs cleaned maf sensor it fixed the problem you might of got some bad gas somewhere go to auto parts store buy a bottle of heet put in the tank it evaporates water
    BassAckwards likes this.
  12. Sep 5, 2019 at 5:02 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
  13. Sep 7, 2019 at 9:16 AM
    jbmdux
    jbmdux [OP] Member
    john
    2015 TRD Off Road
    I am cleaning the MAF and throttle body today (letting it dry while I type this) but the problem was resolved with two tanks of fuel injector cleaner.
    The first one I added at the parts sore into about a 3/4 full tank. After a day I thought it seemed to make a difference. I put the other one in a 1/4 full tank and filled it, half a tank later all was well. I got and tried the STP super concentrated fuel injector cleaner because it was two for 6.99. It worked and yes I was surprised. I typically use the Techron product and have had good results. I also bought the liquid moly jetronic, which I will add next fill up.
    Thanks for the suggestions.
