Running SCS RAY 10 17s. 285/70 ..
Discussion in 'Wheels & Tires' started by jyang627281, Dec 11, 2021.
  1. Dec 11, 2021 at 2:36 PM
    jyang627281
    jyang627281 [OP] New Member
    johny
    2021 cement OR
    Maybe you guys can help me with this. I have a STOCK 2021 TACOMA TRD OFFROAD, I planning to run SCS RAY 10 17s. 285/70 with -10 offset WITH BFG KO2. What do I need to for NO rubbing? I have been seeing a lot of people saying you ONLY need CMC and it will clear. Some say you need 3inch lift with only and it will clear (which I doubt). Some also mention that you need BOTH. So can someone with experience tell which way I can clear 285/70/17 -10mm on my stock Tacoma.
  2. Dec 11, 2021 at 4:02 PM
    Georgeth1022
    Georgeth1022 Well-Known Member
    Shaun
    West Hills CA
    2013 BAJA w/ too many mods
    Too many to list
    If I were you, I’d do all of it. I have the same wheels and rims, I have a CMC, and run Icon stage 9. Approximately a 3” lift, maybe a little more. I also have done the pinch weld, and cut a bit of plastic away on the inside of the wheel wells. After a lot of finesse, I no longer get any rubbing. Except when I hit a dip into a driveway on an angle at good speed lol
    Woodini and jyang627281[OP] like this.
  3. Dec 11, 2021 at 5:21 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I have a 2 inch lift, cmc and plastic trimming and aftermarket UCAs, Icons. Same wheels and tires as you.
    It works awesome, no rubbing and I have flexed it hard out in the bush. You don't need a huge lift, the shocks are going to cycle through their whole travel if you offroad. The plastic trimming isn't that big deal, don't go crazy right away, see where you are rubbing and get out the dremel or utility knife.
    285s look awesome but they aren't big tires compared to what stock jeeps can run.
  4. Dec 12, 2021 at 6:39 PM
    AntSpeed311
    AntSpeed311 New Member
    Anthony
    2021 Tacoma TRD OR with Factory TRD lift kit
    TRD lift kit
    G'day, I have 2021 TRD OR. Would suggest going with the TRD factory lift, that's what I have and just put on BFG KO2 285/70r17 on it; no rubbing. The TRD lift doesn't effect your warranty and no diff drop or UPC alt. Will post pic's.
    jyang627281[OP] likes this.
  5. Jan 17, 2022 at 11:22 PM
    MentalBill
    MentalBill Well-Known Member
    Bill
    Oahu Hawaii
    2018 Civic, 2015 Tundra, 2022 Tacoma (someday soon, on a boat somewhere)
    Need to see them pics.
  6. Jan 17, 2022 at 11:41 PM
    Woodini
    Woodini Well-Known Member
    Ray
    Daytona Beach Shores
    89 Pickup 22RE 4wd
    LCE i/h/e OME susp (install soon) 17” fn counter steer, gonna buy new rubber
    They don’t make it easy on new trucks. Lift is never a bad idea. And if you don’t have the wheels already GOOD LUCK getting them (pick another brand asap)
  7. Mar 13, 2022 at 9:07 AM
    MW20Taco
    MW20Taco Well-Known Member
    Mykle
    2020 TRD OR Premium
    Hello all:
    I’m in a similar position.
    I have a 2” lift all around my 20 OR. I’m running 285/70-17 GDY Duratrac/17x8.5 BR 0 offset wheel (4.75 back space). Generally no issues.
    However I want to know if I can run a -12mm RRW (4.25 back space)?
    I have SPC Adjustable UCA’s but no CMC. I don’t want a CMC…
    All help is appreciated!
  8. Mar 13, 2022 at 10:59 AM
    trungyworld
    trungyworld Well-Known Member
    SLC,UT
    max out the lca all the way forward, find where your tires will clear at the E,F, or G position (E or F will probably do) on your SPC, tell your alignment tech not to touch the lower cams and only adjust camber using the SPC adjustment.
  9. Mar 17, 2022 at 7:08 PM
    Goobsouth
    Goobsouth Active Member
    '01 tacoma trd, '20 trd sport
    They are hard to find, vtx wheels are real close
  10. Mar 17, 2022 at 7:28 PM
    AODRN
    AODRN Well-Known Member
    STL
    2019 Quicksand DCSB Sport
    SCS 17x8.5 -10 offset. 285/70/17. Iron Man Foamcell Pro stage 2 set at 2.5". 4.88 gears. Rear E-locker. KDMax Tuned
    I have the same wheels and tires with no lift and no rub. The details are in my build thread but cmc and pinch weld along with some plastic has to go
    Goobsouth likes this.
