running shitty.
Discussion in '4 Cylinder' started by thmpsntrv91, May 2, 2011.
  1. May 2, 2011 at 2:56 PM
    thmpsntrv91
    thmpsntrv91 [OP] Member
    trevor
    vermont
    91 tacoma
    2.5 inch lift
    hey guys. my 4 banger has been great but my thermostate recently shit the bed. i am getting the part but my truck was stalling before that. would that have anything to do with itt? and no its an auto. not a standard i personaly didnt stall my truck
  2. May 2, 2011 at 3:01 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    When's the last time you did a tune up? (plug/wire/cap and rotor change).
    The thermostat usually won't cause it to stall.
  3. May 2, 2011 at 3:02 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x2 change the ignition stuff, same thing was wrong with my sonoma when I bought it but new plugs, wires, cap and rotor fixed everything.
  4. May 4, 2011 at 12:25 PM
    thmpsntrv91
    trevor
    vermont
    91 tacoma
    2.5 inch lift
    its got new plugs and wires and a distributor, but i figured out the problem. my waterpump went, and it overheated and blew the headgasket. thanks tho.
  5. May 4, 2011 at 1:13 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    oh wow, sorry to hear.
  6. May 4, 2011 at 2:14 PM
    Murrfk
    Murrfk Well-Known Member
    Manitoba, Canada
    1996 Tacoma 2.7l
  7. May 6, 2011 at 11:12 AM
    thmpsntrv91
    trevor
    vermont
    91 tacoma
    2.5 inch lift
    hey thanks murrfk. helps alot.
  8. May 6, 2011 at 8:33 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    It's possible for the engine to stall from a none op thermo. The ECU uses the coolant temp sensor for all kinds of information. If that info is not where it should be cause it's either too cold or too hot then it will not give the proper outputs to the various controls.
  9. May 14, 2011 at 9:39 PM
    thmpsntrv91
    trevor
    vermont
    91 tacoma
    2.5 inch lift
    ok i replaced the head gasket and the temp sensor. but my truck is still running shitty also replace the spark plugs
  10. May 14, 2011 at 9:45 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    did you get the head checked for warpage? Overheating an aluminum head is never good and usually ends up warping the mating surface.
    does it look like the head gasket went again? (white exhaust smoke and disappearing coolant).
    edit: nevermind the aluminum part, just noticed you have a 22re. Still, warping is possible on iron.
  11. May 15, 2011 at 4:13 AM
    thmpsntrv91
    trevor
    vermont
    91 tacoma
    2.5 inch lift
    yeah i did check to see if it is warped but it isnt. and all my coolent is staying this timee.
  12. May 15, 2011 at 8:55 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    how's the compression?
    also when's the last time you changed the fuel filter?
  13. May 18, 2011 at 12:03 PM
    thmpsntrv91
    trevor
    vermont
    91 tacoma
    2.5 inch lift
    i havnt changed the fuel filter since i bought it like 2 yrs ago.
  14. May 18, 2011 at 12:37 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    It might be worth just changing that out although I doubt it would cause the truck to run bad.
    Im stumped, maybe someone else can chime in on this.
  15. May 18, 2011 at 12:59 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    22r or 22re engine?
  16. May 19, 2011 at 1:35 PM
    thmpsntrv91
    trevor
    vermont
    91 tacoma
    2.5 inch lift
    its a 22re engine. and i have replaced the heaad gasket plugs and temp sensor and thermostate. changed the oil and filter and still cant figure out what the problem is. my dad believes its a vacuum leak somwhere. cuz it will idle but when you go to put it in gear and step on the break it stalls. i think its the fuel pump, any ideas?
  17. May 19, 2011 at 10:02 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    sounds like vacuum to me. Get a diagram and check all the hoses.
  18. May 20, 2011 at 12:48 PM
    thmpsntrv91
    trevor
    vermont
    91 tacoma
    2.5 inch lift
    your right it was a vacuum. found err tho. truck was running fine. so we took it for a spin and it was running greatt. but it over heated for some reason on the way home and it blew again this time i gotta get a new head. its warped
  19. May 20, 2011 at 7:39 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Oh my God, that really sucks. I've never heard of anyone having this much trouble with a 22re. Cant they just mill the head down to make it level again?
  20. May 21, 2011 at 3:46 AM
    thmpsntrv91
    trevor
    vermont
    91 tacoma
    2.5 inch lift
    yeah they can. i gotta send them out. ik a place that will give me a deal on them but it will be a couple hundred anyways and then i gotta wait for it to come back
