Running Slightly Hot
Discussion in '1st Gen. Tacomas (1995-2004)' started by Snowman, Jan 7, 2011.
  1. Jan 7, 2011 at 10:39 AM
    Snowman
    Snowman [OP] I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Hey
    Have a little issue with my '04 2.7, it runs a little bit hot. The temp needle is slightly above half when warmed up (maybe 5/8 the way up). I replaced the thermostat which made no difference. Its not leaking any coolant that I can see or smell, dumped the rad when I changed the thermostat so its all new coolant, heat and a/c in the cab work fine and have no effect on the temp. Any ideas?
  2. Jan 7, 2011 at 10:41 AM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Could be an air bubble in the system.
    Check the fins and make sure nothing is blocking air flow.
    Do a flush.
    Water pump could be going bad.
  3. Jan 7, 2011 at 6:13 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Well I completely drained all the coolant when I did the thermostat, so bubbles are not likely and there is nothing blocking the rad in any way. No unusual noise from the wp, but I guess that could be possible. Nothing effects the temp, running the heater, stoped in traffic, towing, revving high, nothing makes the temp change. Its like everything is running normal, but the temp gauge is just slightly higher.
  4. Jan 7, 2011 at 6:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Get a digital temp gauge and check it. It should be running between 185*, and 200*
  5. Jan 7, 2011 at 6:31 PM
    w/chunter
    w/chunter Well-Known Member
    Harrogate, TN
    04 SR5 TRD 4x4
    my '04 runs has ran a little above the half way mark since I purchased my Toyo in July. I thought it was normal. Makes for a good heater in the winter. :)
  6. Jan 7, 2011 at 6:51 PM
    Miata Tech
    Miata Tech Well-Known Member
    Jim
    Lawrence, KS
    2002 4X4 SR-5 TRD
    ChaseCam Video System, Optima YellowTop, ScanGauge II, Heated Drivers Seat, Sirius Satellite Radio, K&N Drop In, E-Locker Guard, Extang Black Max Tonneau , Streamlight Stinger, All Synthetic Fluids, USA-Spec iPhone Interface, Gentex Auto Dimming Compass/Temp Mirror
    Both of my Tacoma's have run a hair over half way on the gauge. Actual coolant temp is 188-193. It's not Really a gauge it's more of an Indicator
  7. Jan 7, 2011 at 7:04 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    hmmm. I bought mine back in Sept, I just cant remember if it was always like that. Maybe the gauge is just a little less than perfect.
  8. Jan 7, 2011 at 7:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Assuming that it used to run cooler on the gauge, why not change the temp sender just for giggles? Can't cost too much.
  9. Jan 7, 2011 at 7:23 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I thought about that, but I hate throwing parts at it not knowing the real problem.
    Nope, clean as a whistle.
  10. Jan 7, 2011 at 7:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    My dash indicator is always slightly more that half way. Nothing seems to effect it. A couple of months ago I got a ScanGauge and found the water temps actually does fluctuate a bit, unlike what the dash indicator shows. The typical normal running temps for my truck range from 192-193*F to 200-202*F. I am guessing it has a "190*" t-stat in it but not really sure.
  11. Jan 7, 2011 at 8:05 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Its good to hear that I'm not the only one like this. Maybe its "normal"
  12. Jan 8, 2011 at 8:52 AM
    mdub
    mdub Active Member
    Missouri
    01 Tacoma Ext Cab
    3" Body Lift 15" Wheels, Over sized Tires
    My 2001 does the same thing. It looks like the needle is just a touch above the middle. I have had it for almost 2 years, flushed the radiator after having it of for 3 months, put in a new thermostat. I think it is normal that it is off just a little. I've had no problems....
    Have fun!
    Mdub.
  13. Jan 8, 2011 at 11:03 AM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    My 1997 and 2003 both showed slightly higher than middle.
    I have an ultragauge on my truck and my truck temperature (digitally displayed from the ECU) runs between 196 and 202 degrees F.
  14. Jan 8, 2011 at 11:31 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    all gauges are crapping. High mass produced parts by the cheapest company they could get them from. The tolerances are not that tight. It's not a gauge that needs to be 100% accurate anyhow. Don't worry about it. it's fine.
