Running Stock or with a Lift?
Discussion in 'Suspension' started by provofan, Dec 6, 2013.
To lift or not to lift?
Poll closed Jan 5, 2014.
  1. Keep it stock
    29 vote(s)
    20.0%
  2. Lift it for the looks
    35 vote(s)
    24.1%
  3. Lift it for the off road improvement
    81 vote(s)
    55.9%
  1. Dec 7, 2013 at 2:19 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Lift it baby!
    Thanks,
    Brett
  2. Dec 8, 2013 at 11:10 AM
    provofan
    provofan [OP] Well-Known Member
    Utah
    13 Black Double Cab TRD Offroad
    What is the best $1000 lift out there?
  3. Dec 8, 2013 at 1:54 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Oh here we go again.:facepalm: (so many options)
    J/k;)
    Thanks,
    Brett
  4. Dec 8, 2013 at 7:08 PM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    I think that if you feel the need to post a thread for others to convince you to lift your truck, you probably won't need it or be happy with spending the $$$. The tacomas are pretty capable in stock trim, so if that's all you need for what you use it for, why waste the $? Just go have fun with it, because I the end, that's all that matters.
    I lifted a little for approach and departure angles, high centering, and to fit larger tires. But I still scrape the front skid, tow hitch and the frame, so I imagine I'd be even worse off without the lift. I spent around $1800 on lift related components. To me, its was worth it and the truck looks better to me as well!
  5. Dec 9, 2013 at 5:44 AM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Bingo.
  6. Dec 9, 2013 at 6:00 AM
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    I actually don't want to lift my truck, because of the potential component headaches caused by angle changes
    However, I do want to get a heavy bumper; so, as bambi and honda accords won't do much more than cause surface scratches, if I T-bone one of them
    I also want to add more than 35lbs of weight in my bed without negatively arching the leafs
    I've yet to find stronger front coils that won't lift the front (well, there's preloaded Toytecs that can be set at 0")
    Could probably find a much stronger leaf pack or add some leafs with lifting the rear little to none
    So, if you plan on doing those things, OP, a (competent) lift should benefit you there too
  7. Dec 9, 2013 at 6:23 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Because kings pull bitches.
  8. Dec 9, 2013 at 6:40 AM
    JLee50
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    I'm sure Alcan could hook you up with a custom leaf pack to do exactly what you're looking for. I was very happy with my Alcan springs on my last truck.
  9. Dec 9, 2013 at 7:32 AM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    For this same reason. My trip to the ranch at 25mph takes a long time with stock suspension. Now with 885's upfront, and 5100's all around and firestone airbags, my trip at 55-60mph is a lot shorter! Now it feels like if I'm floating on air while zooming thru dirt roads.
  10. Dec 9, 2013 at 7:35 AM
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    I lifted mine so I could fit 33's and have more clearance. I do a lot of camping it's easier to go down the trails to get to the campsites with it being lifted. Plus, the area I use to take my dirtbike to had a pretty rocky drive and my frame would slightly scrape in some areas so the lift also took care of that problem.
  11. Dec 9, 2013 at 8:16 AM
    stitch
    stitch PreRunner
    Erick
    Georgia
    04 prerunner sr5 v6 double cab
    none yet
    I was thinking about purchasing OME lift for my first gen cause it an all around lift with good parts. I only chose this lift cause when I was looking for replacement for factory, it was about $800 so I figured an extra 200 or 300 bucks wouldn't hurt.
  12. Dec 9, 2013 at 8:40 AM
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    I haven't lifted my truck yet... But something I'm gonna tell you is that I've been in many places where those 3" would have helped a lot...
    Now, if you think that lifting the truck 3" will not help you with clearance it is because maybe you are thinking that you have a Solid Axle in the front... For gaining clearance in Solid Axles you would only have to change tires...
    With IFS, which is the system that your truck uses, you can obtain clearance by upgrading the suspension (only in the front):
    http://www.youtube.com/watch?v=f98u4_jhU0w
    Sytfu510's ORI struts... you see how you gain some inches in the front?
    If you are still thinking that the lift won't help, don't buy it... Until you need it!
  13. Dec 9, 2013 at 10:17 AM
    provofan
    Utah
    Good to know, great visual
  14. Dec 9, 2013 at 10:23 AM
    provofan
    Utah
    I am leaning to either OME 885 and Nitro or Biistien 5100 with Eibach from Toytec. Both with AAL
  15. Dec 9, 2013 at 10:48 AM
    #35
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    I had the 884s (same spring rate as 885s, just a tad shorter) with the nitros, and bilstens and an aal in the rear on my last truck. I was very happy with it.
  16. Dec 12, 2013 at 12:29 PM
    #36
    cynicalrider
    cynicalrider #NFG
    Jersey
    Currently I am stock and the biggest improvement I have gotten so far was from more aggressive and slightly larger tires. I know on my last trip would have been SOL with stock tires. I was driving behind a lead truck that had a lift and on spots that he made it through without hitting anything, I hit my rear bumper and exhaust pretty damn hard.
    I also have been in trucks that are now mid-travel just by having good shocks and upgraded UCA's. I have seen these trucks handle terrain at 40-50mph where if I did the same in my stock truck I would probably break something, or just have a very painful ride bottoming out my bump stops. That being said if I continue to wheel as much as I have done in the past few months my next investment is sliders, then lift.
  17. Dec 12, 2013 at 6:45 PM
    #37
    dr dave
    dr dave Active Member
    david
    virginia beach
    tacoma, sport, 4X4, white
    this was like sitting on the psychiatrists couch for me, 2012 quad cab, 4X4, long bed, wanting mostly looks, struggling to keep my stock ride. I do the beaches for surf and kiting, and flat land mud for hunting, so don't need but want the lift. You have me thinking I want to maybe just get leveling kit and go up 2 on tires, wheels, call it a day, then get better lighting. still on the fence but enjoyed the thread.
  18. Dec 12, 2013 at 7:26 PM
    #38
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    Pine Canyon in Big Bend National Park this Thanksgiving. Washboard gravel road (big rain storm came through days before). Traveling 25-35mph, could have easily gone faster but was concerned about possible other vehicle traffic on the road (didn't want to frighten anyone). My 70+ year old parents were in the 4Runner with me, weren't uncomfortable, weren't bothered at all - look at the video from around 57 seconds to 1:10....
    Icon low lift suspension, didn't install it to get a lift. Running stock sized Mickey Thompson MTZ's... http://youtu.be/gDtTms_AmxM
    I will be upgrading the suspension on my Tacomas...
    David
  19. Dec 12, 2013 at 8:16 PM
    #39
    Fiend13
    Chad
    Stock are tires are 31" if I remember correctly. If you want to go up 2" in tires then you will need a 3" lift along with some trimming in the wheel wells and a cab mount chop...just a heads up. You can fit 32" tires on stock suspension with minor to no trimming.
  20. Dec 14, 2013 at 12:30 AM
    #40
    jbmccul
    jbmccul Well-Known Member
    2021 GMC Sierra AT4, 2019 Audi A5, 2017 Audi Q5
    It's not necessarily a lift you want. If you're looking to offroad your truck you want to be able to fit the largest tires possible with as little lift as possible. For just hitting some undermaintained roads the stock suspension should do you just fine. However, if you do plan on wheeling, a little trimming can go a long way. Many people on this forum are running 33's and 35's with almost no lift. Colinb17's truck is running 35's with almost no lift. What you are trying to do with your truck will determine any suspension upgrade, if any, that you need. Hopefully this helps!
