running wierd!!
Discussion in '4 Cylinder' started by 99TacomaTRD, Jul 5, 2010.
  1. Jul 5, 2010 at 6:46 AM
    99TacomaTRD
    99TacomaTRD [OP] Member
    Ethan
    Union Ky
    99 tacoma reg cab 4X4
    2inch lift. 32's tube bumpers front and rear
    i have a 99 tacoma with the 2.7. i have put new plugs new wires and used that MAF sensor cleaner. when its sittin there idling it sounds like it has a cam in it or somethin. it seems kinda under powered but then again im not use to a 4 banger. i have also run injector cleaner through it and it still does it. Would a new MAFS fix it? or O2 sensors? :help:
  2. Jul 5, 2010 at 11:30 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    are you sure you got the firing order right?
  3. Jul 5, 2010 at 5:33 PM
    micropiper
    micropiper Admiral of the JOLLY ROGER navy
    damion
    phoenix az
    Four cylinders of pure awesome
    k&n air filter in a modded intake, sliders, new horn, plenty o pinstripes, custom onboard air,cobra cb with custom skidplate,
    get new wires!
  4. Jul 5, 2010 at 5:47 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    sea foam
  5. Jul 6, 2010 at 1:34 PM
    99TacomaTRD
    Ethan
    Union Ky
    yea i have the right firing order. and i just put new wires on it. and ill have to try that sea foam. were can i get it?:mudding:
  6. Jul 8, 2010 at 5:22 PM
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    grab a can at autozone. Only poor half in your vacuum brake line. Let it go until it stalls. let it sit for about 20 min start it up and give it alittle constant 2500k rev. Bunch of blue smoke will come out. Take the rest of the can and throw it in your gas tank.
  7. Jul 8, 2010 at 6:46 PM
    dually
    dually Low and slow
    Interstate underpass
    15 Subaru Outback
    Codes. And are you totally sure about the correct order of the plug wires? The coil packs are numbered with the associating cylinder
  8. Jul 9, 2010 at 6:41 AM
    99TacomaTRD
    Ethan
    Union Ky
    i put the sea foam in the taco and it helped alot with power. its the only toyota ive had that i can cherp 2nd. but it still has a rough idle to it.
    And ive checked the firing order and its all hooked up right.
