Rust Alert: Check your front brake caliper pins
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RichVT, Mar 19, 2019.
  1. Mar 22, 2019 at 6:30 AM
    #41
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    So glad I live in the south....
  2. Mar 22, 2019 at 6:35 AM
    #42
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Jesus not titanium again. Yawn.
    Anyone makes em out of chronin 625 let me know. Otherwise I’ll pass.
    SContiVT likes this.
  3. Mar 22, 2019 at 7:16 AM
    #43
    Not_Sure
    Not_Sure Well-Known Member
    J
    NC
    2019 Model 7545 in Silver Sky
    Bike rack
    Agreed!
    Sorry you northerners have to deal with the rust.
  4. Mar 22, 2019 at 8:11 AM
    #44
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    This and a hundred other reasons!!
  5. Mar 22, 2019 at 8:13 AM
    #45
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    You're not south enough if rust isn't a problem for you...
  6. Mar 22, 2019 at 8:20 AM
    #46
    fe650
    fe650 Well-Known Member
    Will doing this mod improve my gas mileage and whats the biggest tire I can use?
    pinochle likes this.
  7. Mar 22, 2019 at 8:40 AM
    #47
    SContiVT
    SContiVT Back in a Toyota
    Central Vermont
    2010 Tundra Rk Wr/2023 WRX/2023 Ford Exp
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    As a fellow Vermonter who has a buddy with an automotive shop, Brakes can absolutely stick open up here.
    stun gun likes this.
  8. Mar 22, 2019 at 8:57 AM
    #48
    RichVT
    RichVT [OP] Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I just did a brake job on my wife's car. The rear caliper pistons were seized so bad that I broke a C clamp trying to push one back in. Does that mean it was stuck on or stuck open? It was stuck. No amount of brake fluid pressure was going to move it.
  9. Mar 22, 2019 at 9:01 AM
    #49
    SContiVT
    Central Vermont
    Some people do not understand the problems the humidity and road salt cause up here.
    Boghog1 and stun gun like this.
  10. Mar 22, 2019 at 4:45 PM
    #50
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Were you on ih8mud years ago? I guess now too, but I was on years ago and there was a dude with similar name that did the coolest projects, like convert tundra to all wheel drive because with the blower he couldn't get the rear tires to hook up! Haha
    Jowett[QUOTED] likes this.
  11. Mar 22, 2019 at 4:46 PM
    #51
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    You found me. Lol....
  12. Mar 22, 2019 at 5:22 PM
    #52
    TRD493
    Dave
    Texas (DFW)
    The guy has mad skills apparently!
  13. Mar 22, 2019 at 5:26 PM
    #53
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Wow 1 year and they look like its been 20 since new.
  14. Mar 22, 2019 at 5:39 PM
    #54
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    If theyre seized i find using a roll pin air hammer punch works great for getting them out.. i usually just replace them when i do pads. The OEM ones have a coating that seems to hold up for a few winters before rusting
  15. Apr 23, 2019 at 4:38 AM
    #55
    jbmdux
    jbmdux Member
    john
    2015 TRD Off Road
    Trifecta Tonneau Cover
    It is only 2019 right? 4 years and these pins may as well have been welded in.
    Others said design flaw? Maybe cheap parts? Maybe bad assembly at the factory? I am a big believer in grease, the right grease for the right parts, these pins should be doused with high temperature brake grease before installing.
    On mine, the top ones came out okay, a little tapping back and forth but no big deal. The bottoms were the problem.
    After making sure the pads were not stuck to the pins and several attempts with PB blaster, Kroil, two other alleged miracle lubricants and the stuff that gets the parts to -46 degrees, all useless.
    My solution was to take a swazall and cut about a 1 inch piece out of the center of the pin. You can cut where the split in the vented disc are. They came out easily. Tap the inner one out into the gap I created with the cutting. While leaving the pads in place, I used a pin I removed from the top to tap the end of the pin with head out.
  16. Apr 23, 2019 at 4:59 AM
    #56
    jbmdux
    jbmdux Member
    john
    2015 TRD Off Road
    You mean two grams per side
  17. Apr 23, 2019 at 7:44 AM
    #57
    gw204
    gw204 Well-Known Member
    OMC Triple Guard?
  18. Apr 23, 2019 at 8:02 AM
    #58
    jbmdux
    jbmdux Member
    john
    2015 TRD Off Road
    Yamaha makes a nice product too
  19. Apr 23, 2019 at 10:32 AM
    #59
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Nope. I had to look that one up. They came in white tubes with blue writing for grease guns. The heavier stuff came in 5 Gal pails that required torching to make it soft enough to scoop out a handful. I would definitely say industrial strength. It might be the same composition though... Now I definitely need to take a look....
  20. Apr 23, 2019 at 10:47 AM
    #60
    WhiteTaco19
    WhiteTaco19 Well-Known Member
    Sin City
    2019 T4R TRD OR
    I am in Las Vegas. Nothing rusts here lol
    jbmdux likes this.
