Rust already along frame and component welds on new truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by myn75, Dec 24, 2020.
  1. Dec 25, 2020 at 9:16 PM
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    OP: My truck showed the same right from the day of delivery. Undercoat it religiously and don't think twice.
    zoo truck likes this.
  2. Dec 25, 2020 at 9:26 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    Thats great but i don't ever see them putting salt on the road where you live. does it ever get below 45?
  3. Dec 25, 2020 at 9:53 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Salt in the air is just as damaging.
  4. Dec 25, 2020 at 9:58 PM
    jerkwithkeyboard
    Yep my bad. trade you for my minus -10F
    shakerhood likes this.
  5. Dec 25, 2020 at 10:05 PM
    T4RFTMFW
    Move if you’re cold. :)
    jsinnard and shakerhood like this.
  6. Dec 26, 2020 at 6:46 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    fluid film once or twice a year, for the win!
    i never understood people that buy a brand new vehicle for THOUSANDS then, cheap out, and not spend the extra few hundred, to make it last, to protect the investment.
    i live in the snow/rust belt, cars get coated with fluid film (heavily) the first 2 years, to get it into the seams. then after 2 great coats of FF, i coat it with woolwax (same as FF, only a bit thicker, lasts a bit longer, when exposed to constant water, snow, slop, undercarrige cleaning.
    i coat everything that is metal except the brake rotors. the suspension, bolts, and bushings, all look like new. easier to work on when the time comes as well.
    understand the auto mfgr's are not in the business to make cars last, they are in the business to sell cars. they only care if the outside/frame make it to 5 years, to get over the rust through warranty period. the rest is up to the final buyer, to maintain the auto to their liking, and how long they want it to last.
    Ski
    Silentshredr, Bushed and FRE1809 like this.
  7. Dec 26, 2020 at 7:00 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I have never used fluid film or any other rust prevention practices. Why? I believe any truck in the rust belt is going to rust anyway no matter what I do to slow the rust from happening.
  8. Dec 26, 2020 at 7:02 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Put Cosmoline on it once and drive it for 200k. Don't even think about it again.
    pdenajim, zoo truck and mattleg like this.
  9. Dec 26, 2020 at 7:24 AM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    There's a big difference (to me at least) in a vehicle rusting to shit in 8 years vs. 15 years.
    VB25 and Chew like this.
  10. Dec 26, 2020 at 8:52 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I've seen what my neighbors tacoma liked like after 5 years here in connecticut with the rusty frame issues ....so bad toyota bought back the truck. I fluid filmed my 2001 tundra every year starting on its 2nd year after seeing surface rust on the frame everywhere. After 19 years, yeah the frame had a lot of surface rust, but it was solid.
    I did my 2020 tacoma within a few months of ownership with cosmoline. Hopefully its just touchups down the road. It got to be a pita to apply fluid film every fall, not to mention the cost because it washes off. So far this winter the cosmoline still looks great.
  11. Dec 26, 2020 at 10:06 AM
    XTC500
    XTC500 Well-Known Member
    2016 Tacoma 4X4 Double Cab TRD Sport
    Good information above.
    I'm recently retired from a tier 1 auto manufacturer of chassis components. We welded, e-coated & assembled front & rear sub-frames & suspension components for 5 different OEM’s.
    All OEM's are reducing the weight of all components in the quest to meet CAFE requirements. Sub-frames, Lower control arms etc. are designed to the cusp of failure. Meaning they are so thin & light they're barely strong enough to withstand the testing. If they pass the testing with any margin of safety the designers are told to "lighten them up". On top of this, cars are being kept on the roads longer than they used to be. This was a statement from the OEM's & why they have increased their corrosion resistance requirements from 10 years to 15. This has added another challenge to the OEM's to make sure their components do not fail when they reach 10-15 years of corrosion. As we can see, corrosion protection is more important than ever.
    The three N.A. OEM’s now utilize Hot Dipped Galvanized metal. This adds years of life to the component except for the welds & heat affected zone. And those welds on hot dipped are dirtier than ever. The 2 Japanese OEM’s, 20 years ago were ahead of everyone else using electro-galvanized steel when everyone else was using bare steel. Unfortunately they haven't caught up to using hot dipped.
    The capability of E-coating has improved dramatically in recent years. One improvement is a pre E-coating process called neutral de-scale that improves the cleaning of the welds & the black scaly stuff on each side of the weld called the "heat affected zone". This enables the e-coat to stick better in that area. One N.A. OEM was the first to approve the process in our plant. The other 2 N.A. OEM’s bought into it when they saw testing results. One Japanese OEM hasn't made any changes I'm aware of. I should say that I have no idea if this process has been applied by other Tier 1 suppliers or within the OEM paint shops.
    We all know Toyota already had an under body rust problem. Toyota went their own way with changes to the painting process. In our corrosion testing their solution didn't have much measurable improvement compared to the Neutral Descale. But Toyota listens to no-one.
    So my limited observation from one auto parts suppliers perspective, different OEM's have taken different countermeasures to mitigate the risks of their light weight, marginally strong enough components, that might end up on the road for more years than what they used to be. Unfortunately I don't think Toyota is leading edge on this.
    I think it should be expected that you will see rust show up, particularity on the welds & the heat affected zone, on your Tacoma's. No need to panic. If you live in the rust belt, yearly undercoating should make a difference. I DIY Fluid Film each fall.
  12. Dec 26, 2020 at 10:42 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Normal.
  13. Dec 26, 2020 at 11:00 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Because some people also come from cars that have at least some part of the suspension (like lower control arms) made of aluminum alloy and quite frankly less to rust on a unibody car.
    Prior to the Taco, every car I've owned was unibody with some part of the suspension made of aluminum. I never washed under those nor treated with fluid film and there has not been a spec of rust on anything. Granted I'm not in the heavy rust belt but VA use the brine and salt liberaly.
    I agree that you buy it, its your problem but not everyone drove a truck or quite frankly lived somewhere where coatings were a necessity. Its a pita to do and put money towards which also detracts people from doing it.
  14. Jan 1, 2021 at 3:58 PM
    myn75
    myn75 [OP] Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    +1 on the glass like appearance. I remember looking under it and being like "wtf did they clearcoat it?"
  15. Jan 1, 2021 at 4:02 PM
    #35
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Yearly Rustproofing for the Win!
  16. Jan 1, 2021 at 4:04 PM
    #36
    myn75
    Nor Cal
    Is it a problem that ive already took it muddin' without having coated it? im looking at a place that steam cleans and undercoats but im worried preexisting contaminants will be trapped under the undercoat
  17. Jan 1, 2021 at 6:53 PM
    #37
    skidooboy
    central lower mich
    pressure wash it before applying the corrosion protection. they make "brooms" that you attach to a pressure washer. get the majority off, let that dry, then apply the coating. Ski
  18. Jan 1, 2021 at 7:20 PM
    #38
    lynlan1819
    Tacoma
    Lifted
    You must have plenty of money then too buy a new truck every 8-10 years.
  19. Jan 2, 2021 at 5:36 AM
    #39
    batacoma
    batacoma Truck Wars
    Well I don't have plenty of money. I briefly worked a job where I would on occasion presure wash fluid film off of equipment. I didn't like how sticky it was. I also thought that if the pressure washer would take off the FF, so would driving in wet conditions. Pressure washing the FF off did take some effort.
    I also want a new frame so I left the frame untreated.
  20. Jan 2, 2021 at 6:51 AM
    #40
    zoo truck
    None
    You'd need to pressure wash the undercarriage good then get good and dry. Imo, its best these rust inhibitors are applied on a good warm day when the chassis is warm to. I wouldn't worry too much about fluid film sprayed over any contaminants. FF basically encapsulates the chassis even if theres already rust. Stuff like cosmoline is better suited on a new clean frame.
