Rust behind wheel? Help me remedy Plz
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PreRunner, Apr 1, 2010.
  1. Apr 1, 2010 at 12:35 PM
    PreRunner
    PreRunner [OP] Well-Known Member
    2010 Tacoma, removed OEM wheels, replaced with aftermarket. Rust can be seen behind rear wheels, where OEM wheels bolted up. I don't know what this area is called, a drum brake cover maybe? Having rear suspension work done soon, figured id ask them to remove rust and spray it with something flat black?
    What do you guys think :confused:
  2. Apr 1, 2010 at 12:41 PM
    PreRunner
    here is what I'm talking about ...
  3. Apr 1, 2010 at 12:49 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    X2
    It's just your rear drum.
  4. Apr 1, 2010 at 2:55 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yup-It's the rear brake drum- Clean it down and paint it however you'd like (colored or black or whatever)
  5. Apr 1, 2010 at 3:11 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    The drums will look way better with black paint... did mine that way and probably the easiest, most effective dress-up work I've ever done.
  6. Apr 1, 2010 at 3:58 PM
    dimitrik
    dimitrik Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    Won't matter what you paint it, it will rust through the paint fast.
  7. Apr 1, 2010 at 4:06 PM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    Convert to rear disk...lol
  8. Apr 1, 2010 at 4:17 PM
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    08 Prerunner Texas Edition
    paint it rust colored
  9. Apr 1, 2010 at 4:19 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    make sure the parking brake is off, use the two screw method
    ( tightening each screw a couple turns to wiggle the drum off the pads , sorry i dont know the thread size ).
    as you can see this is how mine looked on my 09.
    Once the drum is off, sand it , clean it, paint it.
    May-be a little primer and a good metal paint.
    They will look good and stop most of the rust.
    I have seen up north here where the drum and aliumun rims will rust together if left unchecked, and having the pound the rim off.
  10. Apr 1, 2010 at 4:22 PM
    Brunes
    Brunes abides.
    Rotorhead
    Not if you clean and prep it right. If you spray over the rust you are screwed- but if you do the front work...you'll be fine. (Like I painted mine almost two years ago and they are dirty-but unrusted.
    Horrible idea...Mainly because the folks who have tried it have had little to no success with the "upgraded" brakes.
  11. Apr 1, 2010 at 7:24 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    It's a Toyota, if you remove the rust, it will no longer be a Toyota.....
  12. Apr 1, 2010 at 7:29 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I bit into a lemon once too ,
    OZ
  13. Apr 1, 2010 at 7:57 PM
    Isthatahemi
    TRD OFF ROAD
    A little joke......
  14. Apr 6, 2010 at 8:17 AM
    PreRunner
    Guys, picked up some black caliper/drum paint from pep boys for 8 bux. Since this is a "normal" issue, there has got to be lots of people with this rust. I have a 2010 and it bothered me. It may not bother you. In any event, here is what she looks like now;
  15. Apr 6, 2010 at 8:28 AM
    go8soccer
    go8soccer Memba
    Grovetown, GA
    '08 Super White DC LB Prerunner Sport
    Leaf TSB, front Billie 5100's (1.75"), 265x70x17 BFG Rugged Terrain
    I thought those were the front brakes (rotors) at first, and was like "oh no, he spraypainted the rotors!!!"
    :facepalm:
    :smack:
    :frusty:
  16. Apr 6, 2010 at 8:33 AM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    me too... long night. :pccoffee:
  17. Apr 6, 2010 at 11:25 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Just did my drums this past weekend. Very easy and fun to do
