RUST by design!! (under bed rails)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by neverstuck, May 11, 2013.
  1. May 11, 2013 at 10:54 AM
    neverstuck
    neverstuck [OP] Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Just a heads up to people (and fishing for advice as well), I noticed that the black plastic cap ridge on the top of my bed (bed rails) has been resting on my paint, has worn through the paint all the way around my truck bed, and is causing rust. You can see it very clearly if you lift up the edge of the cap and look under it, where it was resting on the paint.
    I took it to the dealer and they said the paint warranty is long expired and suggested I shop around at body shops for a price. (read: piss off)
    My argument is that it is caused by two toyota parts rubbing on each other and was bound to happen - no fault of mine, poor design by toyota. I'm sure it was caused by the weight of my canopy/shell, but it should be able to handle that weight.
    Thoughts??
  2. May 11, 2013 at 11:05 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    hmmm. I have not noticed this on my ’07.
    also maybe some of it has to do with the area you are in.(very salty air, and probably roads) also moister in the air is probably high as well.(all though, humidity is high most days here till fall.)
  3. May 11, 2013 at 1:57 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I've thought about taking mine off but I also have some missing paint, no rust YET. I do take them off once a year and wax . Sucks living in the rust belt :mad:
    Might be a good idea to sand off the rust and re-paint followed by a good heavy coat of wax. I would just leave the wax on without wiping it off since it's under the cap. I do the same with the fender plastic.
  4. May 11, 2013 at 2:49 PM
    ANT2013taco
    ANT2013taco Well-Known Member
    McAllen Texas
    13 TRD OR 4wd
    I would sand the area down, just enough to rough it up and put down some Herculiner, it will match the bed rails very well and add a cushion of protection. You can actually do the whole bed for less than 100 dollars.
  5. May 11, 2013 at 3:25 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    This is pretty common on trucks with any sort of accessory which rests on the bed rails. The added wait distorts the plastic and causes rubbing.
    A few members have posted before that they took off there bed cap and found the while length under the rails to be rusting.
  6. May 11, 2013 at 3:46 PM
    Drinknmolson
    Drinknmolson Well-Known Member
    Wheat Ridge, CO
    10 DCSB sport
    Yall never saw an 80's toyota bed??
    LOL, i expect to see from one side thru to the other like my '83, oh wait the plastic bed will ruin my view.
  7. May 11, 2013 at 3:53 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Same thing happens on trucks with plastic bed liners in metal beds. Happens on the rails(if the liner covers the rails) and in the actual bed itself. I'd sand it down to bare metal and cover it in bedliner just slightly below the plastic
  8. May 11, 2013 at 4:27 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Start a class action case that seems to be the rage.
    TreeFortRichard and Stryker420 like this.
  9. May 11, 2013 at 5:06 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    '08 with 75,000 and no issues not even any rubs.
    Brett
  10. May 11, 2013 at 6:54 PM
    beandip007
    beandip007 Member
    Kansas City
    2013 Black Taco Sport
    No crap, I would go down the highway and loose pieces of the bed from my 87.
  11. May 15, 2013 at 8:39 PM
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Traded in for a 2013 before the rust becomes apparent. Lots of rust underneath as well but they gave me 22 grand on a trade. DONE DEAL
  12. Apr 17, 2018 at 10:26 AM
    Scortow
    Scortow Member
    Kyle
    2018 Quicksand Tacoma TRD Off-Road 4x4
    Did Toyota fix this issue on the 3rd Gens?
  13. Apr 17, 2018 at 10:31 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Why you scared?!?
    Newfiebruh likes this.
  14. Apr 17, 2018 at 10:33 AM
    Scortow
    Scortow Member
    Kyle
    lol. Yep.
    TacomaMike37[QUOTED] likes this.
  15. Apr 17, 2018 at 6:13 PM
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    I doubt they fixed it lol
  16. Apr 17, 2018 at 6:18 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Yeah they fixed that right after the Rear Leafs.
  17. Apr 17, 2018 at 7:31 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Yeah, i had an 87' Toyota and the design of that bed was ridiculously stupid. You could see the spot welds after a while all along the wheel well areas, and they would rust out where the horizontal seams would meet along each side of the bed.
  18. Apr 26, 2018 at 5:34 AM
    Scortow
    Scortow Member
    Kyle
    Awesome. Thanks for the info
  19. Apr 26, 2018 at 5:39 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    You had me until your last sentence..... ;)
  20. Apr 26, 2018 at 5:47 AM
    planters15
    planters15 Well-Known Member
    Q (irfan)
    Pa - Spring City
    2010 Double Cab SR5 6spd
    Stuff to make go more off road
    @HomerTaco had some pretty bad rust under the bed rails.
