Rust colored coolant?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DrWang, Dec 12, 2010.
  1. Dec 12, 2010 at 7:14 PM
    DrWang
    DrWang [OP] Active Member
    Sonoma County, CA
    06 Access Cab SR5
    Hey everyone,
    I just noticed rust colored coolant in the radiator of my 2006 4 cylinder Taco. Truck has 53K miles so its a bit surprising to have coolant issues (service interval is 100k).
    Will a standard drain/flush/fill of coolant to the trick? Or do I need to take the truck to a shop for a special flush?
    Anyone have opinions on flushing methods?
    I just did this service on my Camry and flushed following directions on the Toyota coolant bottle (drain, fill with water, start engine, open radiator drain, keep level full by filling rad with water, run engine for 10 min, stop engine, drain rad/engine block, fill with coolant). My Chilton was calling for a removal of the thermostat + garden hose which I was too lazy to bother with.
    Will this work on a Taco or should I use the garden hose approach?
    Thanks all! This forum is so sweet.
  2. Dec 12, 2010 at 7:22 PM
    Yakker
    Yakker Member
    New Orleans
    04 PreRunner SR5 Double Cab
  3. Dec 12, 2010 at 7:39 PM
    DrWang
    Sonoma County, CA
    06 Access Cab SR5
    What is so funny?
  4. Dec 12, 2010 at 8:55 PM
    builthatch
    builthatch MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    you sure it's not just the color of the coolant? coolants come in many colors. my 07 honda has blue coolant and my new tacoma has purple coolant. my 08 mazda had brownish orange coolant. what color do you expect it to be, green?
  5. Dec 12, 2010 at 9:25 PM
    tinker_troy
    tinker_troy VAN ENTHUSIAST
    WA
    Blue Subaru Thingamagigy
    x2
    Your coolant should be redish-pink.
    If it's darker, like you imply by calling it rust colored, then yeah you should probably flush it.
    I would go and get a couple gallons of distilled water instead of using a garden hose. Flush it out with that and then fill it up with the toyota pre-mix pink coolant.
  6. Dec 12, 2010 at 9:46 PM
    DrWang
    Sonoma County, CA
    06 Access Cab SR5
    It is definitely not red or pink. I just flushed my 2000 Camry coolant (which is red). The 2006 Toyotas run pink coolant (and it IS pink in the reservoir). Once you see the two side by side, its easy to see the difference.
    But the radiator coolant is orange rust colored. So the question is, will regular flushing get all that crap out or do mechanics have a magical coolant flushing machine?
    I will probably end up using a lot of distilled water and flushing it until it runs clear.
    Thanks all.
  7. Dec 12, 2010 at 9:54 PM
    DrWang
    Sonoma County, CA
    06 Access Cab SR5
  8. Dec 12, 2010 at 9:55 PM
    pinktaco808
    pinktaco808 Hot Steppa
    might be universal
  9. Dec 13, 2010 at 12:41 AM
    NamBam
    NamBam Member
    Birmingham, Al
    2014 DBSC SSM Off-Road
    Dex-cool.
  10. Dec 13, 2010 at 1:19 AM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Just replaced the orange factory stuff on my 99 last winter after it dropped a few points on protection. probably had 160K on it.
    If it is clean and still tests out,,leave it. It can't have corrosion floaties, or its not doing its job obviously.
  11. Dec 13, 2010 at 1:24 AM
    I Liquid I
    I Liquid I Well-Known Member
    Puerto Rico
    06 BSP Double Cab Long Bed
    Too many mods to list
    That doesnt look like "rust" colored coolant to me. :confused: I did have one vehicle which got hot often and the colored showed something that looked like rust... though I am not sure if it'd be the same thing as what you see.
    If you worried, just go to a Toyota Dealer and buy the coolant directly from their service department, chances is it will cost the same as a non crap coolant in any auto place. At least that has been my experience.
    Also, about the green or blue coolant, I am not sure as I am no tech, but a mechanic once told me that some cars, like Jeeps and newer Toyotas that use this red coolant is because they have special additives to avoid rust, additives that cars who use green or blue coolant don't need.
  12. Dec 13, 2010 at 2:54 AM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    The long life coolant in my 2007 was similar color- kind of brown/red.
  13. Dec 13, 2010 at 7:35 AM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    that looks like dex cool to me!
  14. Dec 13, 2010 at 7:39 AM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_ಠ
    17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    Perhaps it had the pink coolant originally and at some point somebody added generic green coolant to it later causing the color to be funky.
  15. Dec 13, 2010 at 8:26 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Looks normal. I was suprised when I checked mine originally (recently had it changed and it still looks the same even new) and was surprised like you, OP. But don't let the color of the radiator fool you! Take some of the coolant you see there out and look at it. It will look totally normal outside of the radiator. You're just looking through the coolant to the radiator color which is distorting the color you're seeing (like looking through something yellow with red behind it will appear orange).
  16. Dec 13, 2010 at 8:29 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    Dex cool comes in chevy products right?
    my 96 S-10 had it, and my mechanic cursed the stuff. he said it gelled with age and would clog things like the heater core. my core made noise like a water fountain. hated that thing.
  17. Dec 13, 2010 at 8:31 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    ^^this^^ I see no issue with that fluid.
  18. Dec 13, 2010 at 8:45 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R TRDOR Premium. ‘01 Tacoma Xtra Cab 4x4
    This
  19. Dec 13, 2010 at 9:27 AM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    yep, it did. it was orangish.
    GM blamed cooling system components, NOT the actual coolant, but regardless ended up paying out due to suits re: dex cool.
    OP, take a turkey baster and draw some of that coolant out of the rad and put it in a clear container to see what it looks like. i think you are ok too.
  20. Dec 13, 2010 at 9:29 AM
    tinker_troy
    WA
    x2
    if your truck isn't overheating, I wouldn't worry about it.
