Rust edges trailer hitch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ronk44, Mar 20, 2022.
  1. Mar 20, 2022 at 7:11 AM
    Ronk44
    Ronk44 [OP] Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I need to do some touch up around my trailer hitch opening as I have a little bit of rust showing. I’ve used my Tacoma to pull trailer a few times this last year. Besides using a steel brush to get it clean what are the suggestions for type of black paint I should use out of a shaker can?
  2. Mar 20, 2022 at 7:15 AM
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    There's no use touching that area up. It’ll come right back the next time your hitch is inserted. That area isn’t going to rust out. If it bothers you, put a hitch plug in to hide it when you’re not towing.
  3. Mar 20, 2022 at 7:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    On the outside of the hitch I'd use something like POR15, then topcoat with Rustoleum or Krylon.
    On the inside of the hitch, if you use it regularly, paint will just come off, so grease works well. Or put a plug on the receiver.
    More importantly, how are you protecting your frame there in salt country?
  4. Mar 20, 2022 at 7:20 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Grease the hitch tube and ball and then bitch about it every time you forget and grab it barehanded. Unless I'm the only idiot that constantly does it.
    Rock Lobster and Jimbo1970 like this.
  5. Mar 20, 2022 at 8:36 AM
    GOROAM
    GOROAM Where can I get Raptor lights?
    19 TRDOR
    Crawling Malls
    :bananadead:
    Stocklocker likes this.
  6. Mar 20, 2022 at 9:27 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I hosed down the inside of my hitch with fluid film every year. In MN, if you leave a hitch in over winter its probably not coming out in the spring, so fluid film and a cap unless I actually need to tow.
  7. Mar 20, 2022 at 9:34 AM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
  8. Mar 20, 2022 at 9:36 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I'll one up you. I'm the dumb bastard that has ruined at least three pairs of khakis from walking into the greased ball in the short time between removing the shin-saver cover and hitching the trailer.
    :anonymous:
    Jimbo1970 likes this.
