Rust fixes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prerunner 06, Apr 15, 2015.
  1. Apr 15, 2015 at 11:23 AM
    prerunner 06
    prerunner 06 [OP] Well-Known Member
    David
    Springfield OH
    06 Prerunner SR5 DCSB
    Hello Taco nuts... I've got some very small rust spots on my tailgate maybe the size of bb's. What's the best (and easiest) way to fix them now before they get bigger. I was thinking about sanding the spot and then using a paint pen over them. Will that work? Thanx in advance for your help.
  2. Apr 15, 2015 at 11:30 AM
    nucktaco
    nucktaco Well-Known Member
    Scott
    south surrey, bc
    08 Double Cab TRD Sport
    satoshi mod, sliders, tinted tails/3rd brake, 3" lift,
    can you post up some pics?
    are you sure its actual rust? alot of times things like rail dust can sit on the surface and rust and you can remove with a claybar and polish.
  3. Apr 15, 2015 at 10:10 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Naval jelly (phosphoric acid) to neutralize the rust. Rinse, dry, and apply touchup paint. Easiest way to use the touchup paint is to apply with the torn end of a paper match. When you touch the paper "brush" to the chip the paint flows into the chip.
  4. Apr 16, 2015 at 11:17 AM
    prerunner 06
    David
    Springfield OH
    Thanx for the replies. The torn match sounds perfect.
  5. Apr 16, 2015 at 8:56 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
