Rust Forming on 07 Tacoma (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Polarisman, Jan 17, 2010.
  1. Jan 17, 2010 at 10:51 PM
    Polarisman
    Polarisman [OP] Active Member
    Vidalia,LA
    07 TRd Sport Double Cab 4X4 with Factory 20's
    Factory Toyota 20 inch rims, on Bridgestone Tires In channel Ventvisors, Window Tint, Bed Mat, Running boards
    Hey guys,
    I was changing the oil in my 07 Tacoma the other day and I noticed this rust on the frame, it flakes off real bad, and is on the same spots on both sides of the truck. The truck has been car-port kept and never been in the mud or salted roads, I live in central Louisiana, only has 6500 miles on it. Do I need to be concerned about this, maybe let the dealer look at it? Any help would be greatly appreciated.
    Thanks,
  2. Jan 17, 2010 at 10:54 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    You are under warrenty take it to the dealer. They will do something for it.
  3. Jan 17, 2010 at 11:17 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    put your fucking camera on MACRO
    please :)
  4. Jan 17, 2010 at 11:59 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    probably just surface rust
  5. Jan 18, 2010 at 12:26 AM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    thats why i undercoated my frame . :)
  6. Jan 18, 2010 at 2:17 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I bought my 2007 used from a guy in Boston, MA. I live in Maryland. I was originally concerned about frame rust from all the road salt the truck has been subjected to and from the stories I've read about Tacomas rusting.
    When I bought it, I pressure washed the undercarriage. It cleaned up nice and had very little rust. What rust it did have seemed to have been hardware and brackets. After I power washed, I sprayed the engire undercarriage with WD40. Before this winter, I power washed and did another application of WD40. I've put 20K miles on the truck since I bought it. We've had 3 good storms already this winter where the roads have been covered with salt. This weekend, I just rinsed off the undercarriage with a garden hose, let it dry and checked it out. No signs of rust anywhere. It looks like new!
    I don't know if I'm lucky or on to something but WD-40 seems to have worked some magic. It takes about 3 cans per application. Give it a try.
  7. Jan 18, 2010 at 2:20 AM
    saf023
    East Coast
    Buy the way, nice looking truck. Wanna sell those wheels?
  8. Jan 18, 2010 at 2:37 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    this may be a complete long shot...and i may have no clue what im talking about
    is it possible that the dealer sold you an 05 and told you it was an 07...and this stems from possible flood damage from Katrina?
    any other issues like seat mounts rusting or things like that?
  9. Jan 18, 2010 at 2:57 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i have an 08 with a rusted frame.dealer told be to fuck off.there is nothing they can do for me.
  10. Jan 18, 2010 at 8:22 AM
    Polarisman
    Vidalia,LA
    Thanks guys,
    I'm gonna take it to the dealer in Baton Rouge and see what they will do.
  11. Jan 18, 2010 at 8:41 AM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    I wish mine had as much paint as yours.
    Marc M
  12. Jan 18, 2010 at 8:44 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I think about all they'll do is tell you it's normal surface rust and send you on your way. If that's the case, if I were you I'd get under there and use some of the products mentioned on other threads here to stop that rust in it's tracks.
    I'm curious on what caused this with the miles you have and the fact that the truck hasn't seen salt. My 07 has 12,500 miles and is pretty much rust free other than around a few weld area's which I went over with rustoleum paint.
  13. Jan 18, 2010 at 8:51 AM
    MurphyZ
    MurphyZ Well-Known Member
    I HATE SPICYTACOS
    Alaska
    97 4runner, 08 Tundy
    89 SAS 3.4 1st gen 4runner- Sold 3.4 swap cut hood for clearance exhaust x-over and magnaflow muffler lockright in the rear SAS 83 toy axle (Wab-Fab) 4xinnovations sliders roof rack from 2nd gen for kayak.
    hahahhahahaa that was fresh:D
  14. Jan 18, 2010 at 8:54 AM
    jimajr
    jimajr Active Member
    Jim
    Pittsburgh, PA
    2010 Pyrite DC TRD Sport
    This company gives their product a lifetime warranty for the frame. Dealer tried to sell it to me when I was in the finance office. They didn't know I live 5 minutes from the place but never knew what they did there. lol. My truck has 800 miles on it so when get my income tax check I'm gonna have it done to my truck.
    http://www.tst5k.com/tst_rust_remedy.html
  15. Jan 18, 2010 at 8:54 AM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
  16. Jan 18, 2010 at 8:58 AM
    danteisme
    danteisme Well-Known Member
    Vandergrift, PA
    06 DCSB Sport, 96 Integra GSR
    my 05 looked a lot worse than that. i have a thread somewhere, i used chassis saver and coated all of teh frame that i could get to.
  17. Jan 18, 2010 at 9:01 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    You bring it into the dealer so it's documented. Keep your receipt, it should have their response on it. For example, when I brought my truck in a week ago for the harsh ride issue, my receipt says "No problem found" which only means they're morons but still, it's documented (FYI: I'm dealing with corporate now).
  18. Jan 18, 2010 at 11:59 AM
    paintdiddy
    shithead
    silver bullet
    they said it a little bit nicer but not much nicer.believe me if i was 10 years younger and dumber or didnt have a daughter i needed to be there for i would have smashed everyones skulls in and than driven through the showroom killing the rest.
  19. Jan 31, 2010 at 1:50 PM
    ywen
    ywen Well-Known Member
    Worst picture ever dude... seriously.
  20. Jan 31, 2010 at 2:14 PM
    guizmouth
    guizmouth Member
    Guizmouth
    Cowansville,Qc, Canada
    2008 4X4 TRD Tacoma (from USA)
    Hehehe guys.
    I'm living in Canada and the first year we've more rust than this and frames are good for over 15 years. Spray a bit of transmission oil once a year and you'll see a big difference. The humidity ans dust together are doing it. It's normal.
