Rust From Running Boards
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Barryo56, Dec 21, 2023.
  1. Dec 21, 2023 at 4:25 PM
    Barryo56
    Barryo56 [OP] Well-Known Member
    Barry
    White TRD Off Raod
    none
    I was thinking of putting factory OEM running boards on my 2019 TRD OR. My son is telling me by doing this it exponentially increases the chances of the cab rusting and will cause the paint to rub off on the pinch welds. Seems far fetched to me but has anyone out there heard of or experienced this issue. Thanks in advance for any insight.
  2. Dec 21, 2023 at 4:31 PM
    tollster64
    tollster64 Well-Known Member
    Pennsyltucky
    2019 TRD DCSB
    I just put a set on my 2019 that are factory OEM, and they simply screwed into existing plugged holes, best of all, they are aluminum and a dense plastic/poly. I couldn’t see anything that would be an issue with the factory, but I coat the shit outa everything with some sort of petroleum product in the rust belt.
    Shellshock likes this.
  3. Dec 21, 2023 at 5:47 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Don't they mount to the frame?
  4. Dec 21, 2023 at 5:49 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    No
    There are many things to worry about. If you keep the truck salt free and relatively clean, rust from running boards should not be a major concern.
    Squirt likes this.
  5. Dec 21, 2023 at 5:49 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can. AMP Powersteps
    Nah they mount on the floor
    Just_A_Guy likes this.
  6. Dec 21, 2023 at 5:50 PM
    Squirt
    Ben
    Dis^
    Just_A_Guy[QUOTED] likes this.
  7. Dec 21, 2023 at 5:51 PM
    Just_A_Guy
    On the hunt
    A truck
    If the running boards cause rust on the cab, I would bet a pretty penny the frame is Swiss cheese by that point lol
    soundman98 and Squirt[QUOTED] like this.
  8. Dec 21, 2023 at 5:52 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    ahh gotcha! :thumbsup:
    I still think they wouldn't cause rust, so long as you are not removing paint, or recovering.
  9. Dec 21, 2023 at 5:54 PM
    Squirt
    Ben
    There's pre drilled and threaded spots to bolt them on. When I put them on my old Tacoma I had to buy a thread tap to chase the threads.
    TS4x4, Just_A_Guy and Chew[QUOTED] like this.
  10. Dec 21, 2023 at 8:10 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    They actually prevent stones from chipping the lower doors and rocker panel areas. I would treat my tacoma with Krown, Fluid Film, Wool Wax, Surface Shield, or Cosmoline prior to the install, and put boards, and bigger mudflaps on, if I was worried about rust. I did this from day one, with my 2019. with 40k on it, the thing looks like new still. Ski
    Shellshock, ljerr2 and RichVT like this.
  11. Dec 21, 2023 at 8:59 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    As others have said… Factory OEM running boards would bolt to the factory OEM mounting points. (underside of cab, already threaded, with plastic plugs)
    Remove the plugs, spray with Fluid Film, Cosmoline or whatever, spray the back side of the mounting brackets, and install the running boards.
    I installed Predator steps on my SR and no concerns about rusting, and absolutely nothing to do with pinch welds.
    Squirt and TS4x4 like this.
  12. Dec 21, 2023 at 9:13 PM
    TacoTuesday1
    FL
    running boards look bad, offer no protection, rip out threads, dent the body, decrease clearance, and get caught/hung up on obstacles and legs
    they don't cause rust.
    offroadguy651 likes this.
  13. Dec 22, 2023 at 3:51 AM
    Barryo56
    Barry
    White TRD Off Raod
    none
    Thanks for all the info. I think they'll be fine as far as rust goes. The truck has been treated with Fluid Film anti is stored inside from December until I get back from Florida in May.
    Chew likes this.
  14. Dec 22, 2023 at 5:12 AM
    ljerr2
    ljerr2 Well-Known Member
    Iowa
    2020 Tacoma TRD Pro
    My $.02 is that steps can help prevent potential rust but at the same time also contribute to potential rust................. They can potentially prevent some rust by helping to deflect road debris before it hits your paint and causes chips and exposed metal. Steps can possibly contribute to rust by creating little areas for things like salt or de-icing solutions from winter roads (if you drive in that type of environment) to collect. Some steps are better or worse depending on how they mount to your truck and clearances they provide between the steps and the cab/body of the truck.
    I have the OEM predator-type steps - not because I like them the best, but they offered me a good compromise of what I wanted - which includes avoiding rust since I live in Iowa. Those steps are aluminum (less oxidation concerns). They attach to factory threaded holes (so no drilling which just invites rust formation if you're not super duper careful). And they don't sit so close the cab that I get a lot of snow/ice collection in the winter that a pressure wand won't blast away. There are many other pros and cons to consider with steps - clearance, accessibility, weight, aesthetics, etc but that's a whole other thread. I also sprayed the attachment points with cosmo just because I hate rust and my truck doesn't see any real offroad action.
  15. Dec 22, 2023 at 8:02 AM
    Renniks
    Renniks Active Member
    Running boards hold that disgusting road snow/salt/rusting agents up against the rocker panels. I am of the opinion that it turbo charged the disintegration of them on my last vehicle.
  16. Dec 22, 2023 at 9:08 AM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    I too have the OEM aluminum boards and I don’t have any rust issues.
  17. Dec 22, 2023 at 9:37 AM
    545
    545 Well-Known Member
    2015 Access Cab
    Definitely can contribute to rust, it doesn’t sound like it will be an issue for you if it’s in storage most of the winter and treated with fluid film
    For those who have never lived in the rust belt, snow and ice, with salt and worse chemical deicers, will build up on them, until it’s solid between the steps and the body. They will hold ice, slush and moisture against the body
  18. Dec 22, 2023 at 12:24 PM
    Barryo56
    Barry
    White TRD Off Raod
    none
    I really like how they look bit'll probably just blow it off for now. Thanks for all the info.
